05-27-2019, 04:49 AM
(05-25-2019, 04:59 AM)pfeerick Wrote:(05-24-2019, 06:58 AM)giel Wrote:(05-24-2019, 02:44 AM)pfeerick Wrote:(05-22-2019, 08:29 AM)giel Wrote: Thanks for your reply! How do I do that from commandline?
There's no need to format anything if you are writing a disk image... it will completely obliterate any prior file system and partition layouts if done properly.
After doing a dd, it may be a good idea to run 'sync' afterwards just to make sure everything has been written to the card before you remove it.
Which model pinebook is it? The original, or the 1080p one? As I gather you need to be using the right image for the different display, or at least change some settings...
It's a brand new 1080 one (11,6 ", I received the pb 2 weeks ago). I've been too busy to buy a new sd-card, which is the most likely cause of the problem I think....
The sd-card I use is working when i use it to store data, but maybe it's too old to use it for booting?
Er... I just looked at your dd command again... that image ain't gonna work for you!
simpleimage is (IIRC) basically a stub image that won't do anything at all as it only has uboot in it... don't quote me on it... it's been over a year since I touched the pine64 image builds!
Try one of the GUI desktop images... ie. https://github.com/ayufan-pine64/linux-b...140.img.xz
Succes! Thanks everyone!! I tried the q4os image for 1080 pinebook! It worked!
