Problem booting from sd-card
(05-24-2019, 06:58 AM)giel Wrote:
(05-24-2019, 02:44 AM)pfeerick Wrote:
(05-22-2019, 08:29 AM)giel Wrote: Thanks for your reply! How do I do that from commandline?
There's no need to format anything if you are writing a disk image... it will completely obliterate any prior file system and partition layouts if done properly.
After doing a dd, it may be a good idea to run 'sync' afterwards just to make sure everything has been written to the card before you remove it.
Which model pinebook is it? The original, or the 1080p one? As I gather you need to be using the right image for the different display, or at least change some settings...
It's a brand new 1080 one (11,6 ", I received the pb 2 weeks ago). I've been too busy to buy a new sd-card, which is the most likely cause of the problem I think....
The sd-card I use is working when i use it to store data, but maybe it's too old to use it for booting?
Er... I just looked at your dd command again... that image ain't gonna work for you!  Big Grin Big Grin
simpleimage is (IIRC) basically a stub image that won't do anything at all as it only has uboot in it... don't quote me on it... it's been over a year since I touched the pine64 image builds!
Try one of the GUI desktop images... ie. https://github.com/ayufan-pine64/linux-b...140.img.xz
Problem booting from sd-card - by giel - 05-17-2019, 02:11 PM
RE: Problem booting from sd-card - by giel - 05-20-2019, 03:20 AM
RE: Problem booting from sd-card - by giel - 05-21-2019, 03:46 AM
RE: Problem booting from sd-card - by dkryder - 05-21-2019, 09:48 PM
RE: Problem booting from sd-card - by giel - 05-22-2019, 08:29 AM
RE: Problem booting from sd-card - by pfeerick - 05-24-2019, 02:44 AM
RE: Problem booting from sd-card - by giel - 05-24-2019, 06:58 AM
RE: Problem booting from sd-card - by pfeerick - 05-25-2019, 04:59 AM
RE: Problem booting from sd-card - by jezek - 05-25-2019, 08:56 AM
RE: Problem booting from sd-card - by pfeerick - 06-27-2019, 10:28 PM
RE: Problem booting from sd-card - by giel - 05-27-2019, 04:49 AM
RE: Problem booting from sd-card - by jezek - 05-22-2019, 10:51 AM
RE: Problem booting from sd-card - by giel - 05-22-2019, 01:56 PM
RE: Problem booting from sd-card - by jezek - 05-22-2019, 03:32 PM
  Buster sound problem fixed yet? Ragnjerr 0 2,108 12-15-2020, 12:23 PM
Last Post: Ragnjerr
  Latest images from different distros failing to boot from SD card jmonty42 2 4,200 11-17-2020, 09:32 AM
Last Post: pagesix1536
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 18,853 04-27-2020, 06:27 AM
  can't install a new OS with sd card. pinebook1080. ObviousHobbit 3 4,146 07-24-2019, 07:52 AM
Last Post: neilman
  DietPi not booting WZ9V 5 6,559 02-01-2019, 09:06 AM
Last Post: smallfish
  Booting from eMMC with SD inserted? falcon15500 6 8,328 07-11-2017, 05:51 AM
Last Post: MarkHaysHarris777
