Rock64 v3 and SD-Cards
(05-08-2019, 09:49 AM)Leapo Wrote: From what I've heard, the issue is that GPIO0_D6 (SDMMC0_PWREN) is left floating by current Linux devicetree configurations, but needs to be set to high or low in order to select an appropriate SDCard voltage.
You can solder a connection between test pad 2302 and 3.3v to revert your Rev3 board's SD-Card slot to Rev2 behavior, which should work with all cards.
If you have a UHS-capable MicroSD card, you can solder a connection between test pad 2303 and ground to force the slot into UHS mode.
Edit: The test pad can be located on the back of the PCB, near the center. I've highlighted it in this drawing, in red: https://i.imgur.com/F9BCSkj.png
It works! I couldn't get it to work connecting it to 3.3V (I'm using UHS cards) but only to ground.
Rock64 v3 and SD-Cards - by Humberg - 05-06-2019, 10:04 AM
RE: Rock64 v3 and SD-Cards - by Luke - 05-08-2019, 02:54 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 05-08-2019, 09:49 AM
RE: Rock64 v3 and SD-Cards - by ketominer - 05-16-2019, 02:50 PM
RE: Rock64 v3 and SD-Cards - by Luke - 05-10-2019, 06:03 AM
RE: Rock64 v3 and SD-Cards - by tllim - 05-12-2019, 03:22 PM
RE: Rock64 v3 and SD-Cards - by dene - 05-13-2019, 01:04 AM
RE: Rock64 v3 and SD-Cards - by PDXpi - 06-05-2019, 06:25 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 05-27-2019, 12:33 PM
RE: Rock64 v3 and SD-Cards - by Luke - 06-02-2019, 08:12 AM
RE: Rock64 v3 and SD-Cards - by Leapo - 02-01-2020, 09:16 PM
RE: Rock64 v3 and SD-Cards - by elibenyaacov - 06-02-2019, 02:04 AM
RE: Rock64 v3 and SD-Cards - by igorp - 06-06-2019, 12:48 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 285 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,325 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,683 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,148 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 336 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,887 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,531 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,103 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 758 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 953 10-07-2022, 07:50 PM
Last Post: rookie_267
