Clusterboard startup issues
(05-07-2019, 02:45 PM)WhiteDragon Wrote: At the moment I'm using Armbian 5.84 Debian Stretch with a 4.19.38 Kernel I built from source. It didn't work out of the box though.
I had to apply this fix described in the Armbian forums linked above.
I figure that the USB Network Dongle was mapped to a lower Hardware ID and the SoPine can only maintain a single network connection, thus the onboard NIC on the SoPine Module was deactivated. I figured furthermore that the switch on the Clusterboard is only powered, when at least one of the NICs on the SoPine Modules tries to communicate with it (I guess some sort of XOR gate controlling V_in or somesuch nonsense).
Since that did not happen due to the network bug the switch stayed "dark".
When I wrote my guide, the LTS was the only one that worked.  I've gotten them to fix it since and add nightly builds to the download page.  I also see they built a new image as of 5/3 so I'll have to test it out.  All the images were working as of 5/3 but I'll have to check the new ones.
I just got both of the 5/3 (Debain and Ubuntu) images to work.  I cannot duplicate the problem you're having.
Clusterboard startup issues - by WhiteDragon - 05-05-2019, 03:32 PM
RE: Clusterboard startup issues - by WhiteDragon - 05-06-2019, 06:10 AM
RE: Clusterboard startup issues - by WhiteDragon - 05-07-2019, 02:45 PM
RE: Clusterboard startup issues - by AZClusterboard - 05-08-2019, 12:13 PM
RE: Clusterboard startup issues - by WhiteDragon - 05-08-2019, 04:21 PM
RE: Clusterboard startup issues - by WhiteDragon - 05-09-2019, 06:07 AM
RE: Clusterboard startup issues - by WhiteDragon - 05-09-2019, 12:32 PM
RE: Clusterboard startup issues - by WhiteDragon - 05-09-2019, 01:34 PM
  Managed Ethernet switch on the Clusterboard dsimic 6 5,434 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 5,884 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 1,631 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 12,598 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 5,263 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 2,084 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 23,403 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 3,834 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 7,346 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 6,223 08-15-2020, 07:31 AM
Last Post: poVoq
