Help with getting a Marvell 9230 to work
(05-05-2019, 09:57 AM)nuumio Wrote: Yeah! I saw that in my research, but I still had a couple questions. I don't have that file in my udev folder though. Is it something I need to create myself? And if so, is there any content inside of that file, or is it just blank? I've switched to Ubuntu because it seems like that has more support for the marvell chips.
You'll have to create that file and then copy/paste this one line into it:
ACTION=="add", SUBSYSTEM=="pci", ATTR{vendor}=="0x1b4b", ATTR{device}=="0x9230", RUN+="/bin/bash -c 'echo %k > /sys/bus/pci/drivers/ahci/bind'"
Edit: Adding the line above /etc/udev/rules.d/99-marvell.rules will make the change permanent.
This method worked with Ayufan's kernel and Openmediavault 5 using the last Ayufan's pre-release (0.10.12).
Music Lover first.
IT Lover second.
RockPro64 owner 4G with WD Red 4T
RE: Help with getting a Marvell 9230 to work - by aldrick - 05-14-2020, 06:49 AM
  Sata Raid Marvell 4port 9235 stuartiannaylor 1 3,136 07-04-2019, 08:12 PM
Last Post: stuartiannaylor
  Getting any IR remote to work with the RockPro64 ? michbucanon 0 2,395 05-15-2019, 03:47 AM
Last Post: michbucanon
