Rock64's temperature while being in aluminium case
(06-20-2019, 07:53 AM)rasputin Wrote:
(04-17-2019, 01:29 PM)_zernok Wrote: Hello,
I am about to order from pine64 website these : 1 Rock64 4GB, 1 EU power supply, 1 heatsink and 1 "Model B" premium aluminium casing.
I wonder how the Rock64 is doing while being locked up that aluminium case as I don't see any openings. Is this casing effective at keeping the Rock64 cool (or not too warm ^^) ?
Anyone to shut my concerns down ? Smile
Thanks a lot Smile
Hi _zernok, hi forum!
I recently purchased a Rock64 (4GB version) and a "Modell B" Premium Aluminium Casing. I successfully installed DietPi (downloaded from https://dietpi.com/) on a 16GB eMMC. Unfortunately, the SBC crashes occasionally with a kernel panic.
I assume the cause is a thermal problem. I used the tool stress and could reproduce the failure. With low load, the Rock64 runs stable for days.
I tried to catch the kernel panic message, but I have currently no sufficient UART level converter at hand that is fast enough for the 3 Mbaud serial console of the Rock64 (only a CP2102-based one). This way, I hope to get some information which point to the root cause of the kernel panic.
The cover of the casing features a "L"-shaped "heatpipe" inside that attaches to the SOC and memory chip of the Rock64 via a thermal compound. Hence, there is no simple way to attach an additional heat sink to the Rock64 inside the casing.
Does anyone have/had the same problem and an idea how to fix this?
Thank you in advance!
Regards,
rasputin
with proper thermal compound on the L-shape heatpipe and ROCK64 SoC surface, the heat should be able distribute to whole Aluminum case.
RE: Rock64's temperature while being in aluminium case - by tllim - 06-23-2019, 12:46 AM
  DeskPi case alternative for ROCK64 v1k699 2 11,058 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 2,717 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,362 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,200 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 9,133 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 3,375 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 4,454 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 6,292 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 5,585 06-08-2022, 12:44 AM
Last Post: Zoz
