rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz?
Hello.
I think that DDR initialization before uboot can be modified later in linux with DMC+DFI. There are enabled DMC+DFI in (some) ayufan builds.
If enabled you can dynamically set "DDR" speed (set governor,min,max...). I have stability issues with 1066000000 (4K60HDR decoding). Maybe "rk3328_ddr_333MHz_v1.13.bin" allows only lower frequencies (post output "cat /sys/class/devfreq/dmc/available_frequencies").
# grep '' /sys/class/devfreq/dmc/*
/sys/class/devfreq/dmc/available_frequencies:786000000 800000000 850000000 933000000 1066000000
/sys/class/devfreq/dmc/available_governors:dmc_ondemand userspace powersave performance simple_ondemand
/sys/class/devfreq/dmc/cur_freq:786000000
/sys/class/devfreq/dmc/governor:dmc_ondemand
/sys/class/devfreq/dmc/max_freq:1066000000
/sys/class/devfreq/dmc/min_freq:786000000
/sys/class/devfreq/dmc/polling_interval:50
/sys/class/devfreq/dmc/system_status:0x401
/sys/class/devfreq/dmc/target_freq:786000000
/sys/class/devfreq/dmc/trans_stat:   From  :   To
/sys/class/devfreq/dmc/trans_stat:         :7860000008000000008500000009330000001066000000   time(ms)
/sys/class/devfreq/dmc/trans_stat:*786000000:       0       0       0       0       0     97457
/sys/class/devfreq/dmc/trans_stat: 800000000:       0       0       0       0       0         0
/sys/class/devfreq/dmc/trans_stat: 850000000:       0       0       0       0       0         0
/sys/class/devfreq/dmc/trans_stat: 933000000:       0       0       0       0       0         0
/sys/class/devfreq/dmc/trans_stat: 1066000000:       0       0       0       0       0         0
/sys/class/devfreq/dmc/trans_stat:Total transition : 0
# echo 933000000 > /sys/class/devfreq/dmc/max_freq
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
RE: rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? - by mcerveny - 04-16-2019, 06:28 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 279 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,304 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,657 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,113 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 332 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,875 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,519 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,091 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 756 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 949 10-07-2022, 07:50 PM
Last Post: rookie_267
