4 Uarts and 2 Ethernet possiblities
(06-27-2019, 11:23 AM)pistoletov Wrote:
(06-27-2019, 09:29 AM)martinayotte Wrote: Beware that you also need to control RTS for RS485 flow direction ...
If you don't want to bother with driver or this flow direction, you are better luck using a USB-RS485 dongle such as this one :
https://www.ebay.ca/itm/2PCS-CH340-USB-t...1911412433
thank you for reply.  I know about this pin for direction. In other forum (armbian) i saw yours post about using RTS signal for this. I have a allwiner board to but i can't find kernel module which support  uart  rts signal.  I know about usb-485 adapters whis is cheap but i do not have free usb ports..
RS485 might be difficult to control via software, if the speeds are high.
Actually, you might consider a Beaglebone Black or Green.  It has 5 UARTs available, and it can support RS485 with buffers (like the MAX485).  You can plug in a second Ethernet via USB.
4 Uarts and 2 Ethernet possiblities - by gops - 04-04-2019, 12:20 PM
RE: 4 Uarts and 2 Ethernet possiblities - by gops - 04-04-2019, 08:17 PM
RE: 4 Uarts and 2 Ethernet possiblities - by LMM - 04-05-2019, 09:58 AM
RE: 4 Uarts and 2 Ethernet possiblities - by gops - 04-05-2019, 01:07 PM
RE: 4 Uarts and 2 Ethernet possiblities - by LMM - 11-13-2020, 08:51 AM
RE: 4 Uarts and 2 Ethernet possiblities - by richardk - 06-27-2019, 03:47 PM
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,396 01-17-2023, 02:31 PM
Last Post: Flagtrax
Tongue RockPro64 Ethernet NOP After Debian 11 Install... MattDralle 1 2,081 10-30-2021, 06:10 AM
Last Post: Rocklobster
  USB3 to Ethernet adapter giuseppe 0 1,673 11-11-2020, 05:48 PM
Last Post: giuseppe
  UARTs from GPIO headers maks.dav 1 2,332 10-27-2020, 12:06 PM
Last Post: martinayotte
  No green Ethernet LED sanis 2 3,904 03-06-2019, 11:21 PM
Last Post: sanis
  flash image to sd/emmc through ethernet LMM 0 2,231 02-04-2019, 07:36 AM
Last Post: LMM
  Rock64 ethernet problems ushills 4 6,095 05-29-2018, 05:16 PM
Last Post: pfeerick
  u-boot doesn't receive packets over ethernet hibernick 3 4,017 01-12-2018, 12:38 AM
Last Post: hibernick
  rock64 ethernet port sticker dkryder 1 3,360 11-14-2017, 10:18 PM
  Rock64 Ethernet LED Problem gaz2613 5 5,362 10-01-2017, 08:59 AM
Last Post: stuartiannaylor
