Rockpro64 boot issues
(03-22-2019, 04:46 AM)larsgn Wrote:
(03-21-2019, 04:51 PM)larsgn Wrote:
(03-21-2019, 03:02 PM)z4v4l Wrote: I might be wrong, but 3.5'' disks need 12 V power to spin up. Are you sure, you provide it? For example the power cable in the Pine64 store has as output only 5 V, thus it's for 2.5'' hdds and ssds.
I feel really stupid right now, how could I've missed this. So obvious, thanks for pointing out!
Added a seperate picopsu to provide 12v to the 3.5" disk, still no luck.
The behaviour is the exact same.
3.5" drives do not run on the 12v rail. The adapter from the Pine store that steps down to 5v 3A is correct and works fine for me running two 3.5" NAS drives. So am I correct in assuming that you are not using the power supplied directly from the board? If you are using a separate power supply (outside of a case) have you jumped the pins to make it turn on ? Again, 12V is not what you need for your HDDs. Sorry, I don't know why you are having these issues.
Rockpro64 boot issues - by larsgn - 03-21-2019, 02:02 PM
RE: Rockpro64 boot issues - by z4v4l - 03-21-2019, 03:02 PM
RE: Rockpro64 boot issues - by larsgn - 03-21-2019, 04:51 PM
RE: Rockpro64 boot issues - by larsgn - 03-22-2019, 04:46 AM
RE: Rockpro64 boot issues - by usauwf - 03-22-2019, 08:53 AM
RE: Rockpro64 boot issues - by usauwf - 03-22-2019, 08:42 PM
RE: Rockpro64 boot issues - by codemonkey - 04-23-2019, 02:23 AM
RE: Rockpro64 boot issues - by Bullet64 - 04-23-2019, 11:15 AM
RE: Rockpro64 boot issues - by larsgn - 07-31-2019, 02:07 AM
RE: Rockpro64 boot issues - by larsgn - 07-31-2019, 04:29 AM
RE: Rockpro64 boot issues - by buzzmarshall - 07-31-2019, 07:59 AM
RE: Rockpro64 boot issues - by imapc99 - 08-01-2019, 12:12 PM
RE: Rockpro64 boot issues - by Lanza - 08-25-2020, 08:15 AM
RE: Rockpro64 boot issues - by fotastisch - 09-27-2020, 04:44 AM
RE: Rockpro64 boot issues - by quinterro - 10-21-2020, 07:54 AM
  Installing Wifi drive for the RockPro64 John45595 0 309 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 9,431 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 119,509 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 757 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 667 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 683 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,257 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,318 05-18-2023, 10:46 AM
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 891 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,326 04-06-2023, 02:46 PM
