PCIe failure
Just received my RockPro64, NAS case, and all the goodies.  I installed the Ubuntu Bionic LXDE image, loaded up great, added ATS, etc.  Everything is great except that the 2 WD Reds are not recognized.  Opening the case back up, I see that the PCIe doesn't have its LED lit up.  I'm trying to decide if this is the img or the hardware.  I have gotten the LED to illuminate a couple times by unplugging the SATA cables, but it doesn't stay on.  Also, during boot, the LED will blink on and off, then stay off.  lspci -v shows nothing, df -h / fdisk -l do not show the HDDs.
I do not have the board that requires removing a resistor.
boot log for pci:
[ 0.505675] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[ 0.505723] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[ 0.505761] vcc3v3_pcie: supplied by dc_12v
[ 0.505828] vcc3v3_pcie: 3300 mV
[ 0.505988] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[ 1.166830] ehci-pci: EHCI PCI platform driver
[ 2.894277] vcc3v3_pcie: disabling
[ 3.257493] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[ 3.257501] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[ 3.260566] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[ 3.260590] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[ 3.260679] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[ 3.261231] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 3.261553] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[ 3.261575] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 3.261629] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 3.276048] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[ 3.276086] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 3.276142] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 3.290608] rockchip-pcie f8000000.pcie: invalid power supply
[ 3.350984] PCI host bridge /pcie@f8000000 ranges:
[ 3.387121] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 3.394721] pci_bus 0000:00: root bus resource [bus 00-1f]
[ 3.401970] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[ 3.409375] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[ 3.417072] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[ 3.417190] pci 0000:00:00.0: supports D1
[ 3.417196] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 3.417676] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.425545] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-1f] (conflicts with (null) [bus 00-1f])
[ 3.425588] pci 0000:01:00.0: [1b21:0612] type 00 class 0x010601
[ 3.425642] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 3.432368] pci 0000:01:00.0: reg 0x10: [io size 0x0008]
[ 3.432397] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[ 3.438957] pci 0000:01:00.0: reg 0x14: [io size 0x0004]
[ 3.438971] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[ 3.445415] pci 0000:01:00.0: reg 0x18: [io size 0x0008]
[ 3.445429] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[ 3.451804] pci 0000:01:00.0: reg 0x1c: [io size 0x0004]
[ 3.451818] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[ 3.458122] pci 0000:01:00.0: reg 0x20: [io size 0x0020]
[ 3.458137] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 3.458150] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 3.460470] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.460537] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff]
[ 3.470994] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[ 3.497156] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa0101ff]
[ 3.504734] pci 0000:01:00.0: BAR 4: no space for [io size 0x0020]
[ 3.510579] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0020]
[ 3.516276] pci 0000:01:00.0: BAR 0: no space for [io size 0x0008]
[ 3.521936] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0008]
[ 3.527605] pci 0000:01:00.0: BAR 2: no space for [io size 0x0008]
[ 3.532503] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0008]
[ 3.537180] pci 0000:01:00.0: BAR 1: no space for [io size 0x0004]
[ 3.541789] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0004]
[ 3.546404] pci 0000:01:00.0: BAR 3: no space for [io size 0x0004]
[ 3.550983] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0004]
[ 3.555226] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.559035] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff]
[ 3.563143] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.567436] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 3.571440] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 3.575103] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[ 3.575213] aer 0000:00:00.0:pcie02: service driver aer loaded
PCIe failure - by odhinnhrafn - 03-19-2019, 02:32 PM
RE: PCIe failure - by tvmaster3 - 03-20-2019, 09:34 PM
RE: PCIe failure - by tvmaster3 - 03-21-2019, 10:09 PM
PCIe failure - by odhinnhrafn - 03-23-2019, 10:35 AM
RE: PCIe failure - by tvmaster3 - 03-24-2019, 12:14 PM
RE: PCIe failure - by hexxx - 08-11-2019, 12:04 PM
RE: PCIe failure - by tvmaster3 - 03-25-2019, 05:45 AM
RE: PCIe failure - by tvmaster3 - 04-12-2019, 02:43 AM
RE: PCIe failure - by vorondil - 08-09-2019, 03:52 PM
RE: PCIe failure - by hexxx - 08-11-2019, 12:08 PM
RE: PCIe failure - by mmatyas - 08-12-2019, 03:24 AM
RE: PCIe failure - by odhinnhrafn - 03-16-2020, 08:39 AM
  Compatible PCIe Sata Controller spacebricker 1 5,628 02-06-2023, 10:03 AM
Last Post: diizzy
  PCIe bifurcation support (on RK3399) Arn 1 5,685 11-28-2022, 05:12 PM
  NAS case HDD power cable failure (buck failure) ashleymills 1 4,683 04-01-2022, 11:25 AM
Last Post: ashleymills
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 7,728 11-27-2021, 11:38 PM
Last Post: Cerberus
  Carte PCIe bloquant le démarrage du Noyau / PCIe card blocking Kernel boot dml-pc 4 9,695 02-17-2021, 11:35 AM
Last Post: dml-pc
  Nvidia GPU on PCIe User 18962 4 8,903 12-22-2020, 02:54 PM
Last Post: amiraeva
  Won't boot with 2.5GBe PCIe adaptor connected voltagex 1 5,200 10-20-2020, 12:22 PM
Last Post: xmixahlx
  RockPro64 pcie Gpu Davidos 8 23,208 07-14-2020, 05:11 PM
Last Post: ProDigit
Question Can we add PCIE hub 1 to many pcie card seaurchin 1 5,480 11-25-2019, 11:08 AM
  Tested PCIe cards and output kram0000 5 10,385 10-24-2019, 01:17 PM
Last Post: xalius
