Have eMMC adapter - but can't seem to fix eMMC card
Of course, it's not lost. You should have flashed it (with that etcher), insert into rock64 and use. why did you do differently? I guess, you use an image that has rockchip GPT partitioning with a lot of partitions. it might cause many old utilities to behave erratically, some partitions might have IDs indicating their "special" role on the system, prohibiting a compliant environment to mess up with them. you need some hammer. Big Grin maybe you try armbian with their good old MBR scheme and just 1 partition. try use windiskimager for flashing it and let armbian resize its volume on the first boot. there are also tons of other methods to get your eMMC back to the normal state. for example - insert it into rock64 booted with sd card and fill some first megabytes of the raw device with zeros. with dd. make sure you zero eMMC, not SD card. Big Grin
ANT - my hobby OS for x86 and ARM.
RE: Have eMMC adapter - but can't seem to fix eMMC card - by z4v4l - 03-20-2019, 03:18 PM
Question Compatible eMMC modules and benchmarks danboid 7 21,322 03-09-2023, 08:14 AM
Last Post: arvendui
  DAC (ES9023) addon card on other SBCs like rpi? AlexS 1 3,925 08-28-2021, 04:53 AM
Last Post: CounterPillow
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 14,889 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 2,608 05-03-2019, 01:32 AM
Last Post: pcosm
  emmc module help default_user8 1 4,212 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 2,590 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 5,451 12-01-2018, 03:53 AM
Last Post: jovval
  Dead eMMC? machina 8 13,201 11-21-2018, 05:05 AM
Last Post: machina
  FORSEE eMMC is reliable? ramprasad 3 7,373 11-12-2018, 03:34 PM
Last Post: Tortax
  50 kb with RTL8188eu WIFI adapter Juice4 2 5,203 11-09-2018, 12:56 PM
Last Post: Juice4
