Feature Complete Debian Desktop Release
#72
(03-26-2019, 01:35 PM)fysa Wrote: Some things to try for Cura -- you may need to recompile it?  But I think forcing GL 2.1 for GLES worked.
LIBGL_GL=21 cura
Cura is Qt so it supports -platform also, you can play with that:
LIBGL_GL=21 cura -platform xcb
Will be playing with this in a bit here ..
I have tried these suggestions and more.   I even compiled mesa from source and built a working software only libGL.so.1 and provides up to 3.3 context instead of only 2.0 from gl4es.  This works when I set LD_LIBRARY_PATH but it is of course slower.
Despite this, I cannot get Qt built with "./configure -opengl desktop" to work.  With either gl4es or the mesa library the result is exactly the same running any qt program including the opengl examples in qt:
Cannot find EGLConfig, returning null config
Unable to find an X11 visual which matches EGL config 0
Segmentation fault
I don't understand why it is using EGL at all.   I don't want to use EGL only GLX.  I know this is probably deprecated, but I just want to run Qt with desktop gl and I don't care if it's accelerated.   I suspect that Qt has something hardcoded to use EGL specifically for armhf.  Likely the developers only used armhf platforms with GLES, and did not consider desktop gl.
Without desktop GL neither Cura nor openscad will work.   It might be an interesting exercise to make them work in a GLES Qt, but I am not a developer of either so it would be a difficult task.
I have plenty of other opengl programs that are not Qt based, and all of these work fine.
RP64 noob - by ziibii88 - 03-16-2019, 12:49 AM
RE: RP64 noob - by Mrfixit2001 - 03-16-2019, 08:06 AM
RE: RP64 noob - by ziibii88 - 03-16-2019, 10:11 PM
RE: RP64 noob - by Luke - 03-17-2019, 03:36 AM
RE: Feature Complete Debian Desktop Release - by seandepagnier - 03-27-2019, 08:34 PM
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,474 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 2,226 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,563 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 4,626 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 5,474 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 13,106 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,424 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,151 09-30-2021, 11:54 AM
Last Post: publiclewdness
