Feature Complete Debian Desktop Release
#68
(03-17-2019, 07:49 PM)futurejones Wrote: Absolutely awesome work! This is without doubt the best performing and looking desktop available.
Thanks for all your hard work making this possible.
One problem -
I have the PCIe m.2 adapter with a 250GB WD Black nvme ssd attached.
When I log in as root everything is working beautifully. Desktop is smooth and access to PCIe ssd works as expected. But....
When I try to log in as "rock" everything freezes and I have to restart the rockpro64.
This seems to be the same issue I have had with all other distro desktop installs I have tried except they won't boot even as root.
For now I am very happy just to be able to use as root.
I've had a rockpro64 for some time but just starting to explore this desktop image, which I hope will make this nice hardware more useful all-round.  Seems I have the same issue as you - when I log into desktop as rock it crashes, but login as root is OK. I'm also using PCIe-SATA  which works fine by ssh, even logged in as rock. Then I found, +/- by chance, that rock desktop login works OK *after* I uninstalled pulseaudio. Note that pulseaudio is normally disabled for root anyway. The clue was little clicks in headphones coinciding with moment  the "busy" blob froze on crashing. So now have  login as rock, but no sound ...    Meanwhile struggling with wifi / bt (devices see each other but not connecting), will keep trying.
In general it's progress - at least I can now open the sata drive and view photos stored there (months ago using an ayufan distro -  then it was either pcie or desktop, but not both together).  Thanks to all who work on it,  and hope all  solveable soon.
RP64 noob - by ziibii88 - 03-16-2019, 12:49 AM
RE: RP64 noob - by Mrfixit2001 - 03-16-2019, 08:06 AM
RE: RP64 noob - by ziibii88 - 03-16-2019, 10:11 PM
RE: RP64 noob - by Luke - 03-17-2019, 03:36 AM
RE: Feature Complete Debian Desktop Release - by benjhm - 03-26-2019, 09:57 PM
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,474 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 2,226 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,563 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 4,626 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 5,474 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 13,106 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,424 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,151 09-30-2021, 11:54 AM
Last Post: publiclewdness
