Feature Complete Debian Desktop Release
#64
I really appreciate the enormous work which was put into this distribution and the philosophy 'make this nice computer work'.
Unfortunately, when installing the distribution on my RockPro64, I get to the login page, but when logging in the system freezes and it seems that the difference to the previous distributions I have tried are not all that big? I have a configuration with a SATA disk. Here is my kern.log with '|grep failed'. This is _before_ I try to log in. I have so far not found a good log providing a clue about the desktop login problems. Login with ssh (before desktop login) is not a problem (and has never been).
Any Idea what is wrong here?
Mar 23 06:27:13 localhost kernel: [ 0.582850] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
Mar 23 06:27:13 localhost kernel: [ 0.583989] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
Mar 23 06:27:13 localhost kernel: [ 0.584031] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
Mar 23 06:27:13 localhost kernel: [ 0.621483] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
Mar 23 06:27:13 localhost kernel: [ 0.621769] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
Mar 23 06:27:13 localhost kernel: [ 0.623402] phy phy-ff7c0000.phy.7: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
Mar 23 06:27:13 localhost kernel: [ 0.623531] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
Mar 23 06:27:13 localhost kernel: [ 0.627588] rockchip-drm display-subsystem: failed to parse loader memory
Mar 23 06:27:13 localhost kernel: [ 0.627637] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
Mar 23 06:27:13 localhost kernel: [ 1.687315] rockchip-spdif ff870000.spdif: ASoC: pcm constructor failed: -22
Mar 23 06:27:13 localhost kernel: [ 1.687328] asoc-simple-card spdif-sound: ASoC: failed to instantiate card -22
Mar 23 06:27:13 localhost kernel: [ 1.687480] asoc-simple-card: probe of spdif-sound failed with error -22
Mar 23 06:27:13 localhost kernel: [ 2.530797] cdn-dp fec00000.dp: [drm:cdn_dp_request_firmware] *ERROR* failed to request firmware: -11
Mar 23 06:27:13 localhost kernel: [ 2.556954] rockchip-saradc ff100000.saradc: Looking up vref-supply property in node /saradc@ff100000 failed
Mar 23 06:27:13 localhost kernel: [ 2.617420] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
Mar 23 06:27:13 localhost kernel: [ 3.182856] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0020]
Mar 23 06:27:13 localhost kernel: [ 3.182871] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0008]
Mar 23 06:27:13 localhost kernel: [ 3.182887] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0008]
Mar 23 06:27:13 localhost kernel: [ 3.182900] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0004]
Mar 23 06:27:13 localhost kernel: [ 3.182917] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0004]
Mar 23 06:27:13 localhost kernel: [ 3.187508] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
Mar 23 06:27:13 localhost kernel: [ 3.187647] dwmmc_rockchip fe310000.dwmmc: failed to enable vmmc regulator
Mar 23 06:27:14 localhost kernel: [ 3.238999] dwmmc_rockchip fe310000.dwmmc: failed to enable vmmc regulator
Mar 23 06:27:14 localhost kernel: [ 3.288928] dwmmc_rockchip fe310000.dwmmc: failed to enable vmmc regulator
Mar 23 06:27:14 localhost kernel: [ 3.342741] dwmmc_rockchip fe310000.dwmmc: failed to enable vmmc regulator
Mar 23 06:27:14 localhost kernel: [ 3.990700] failed to power up DHD generic adapter, 1 retry left
Mar 23 06:27:15 localhost kernel: [ 4.627439] ttyS0 - failed to request DMA, use interrupt mode
Mar 23 06:27:15 localhost kernel: [ 4.790298] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:15 localhost kernel: [ 4.790317] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:15 localhost kernel: [ 4.790325] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:15 localhost kernel: [ 4.790332] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:15 localhost kernel: [ 4.790339] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:15 localhost kernel: [ 4.790346] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 6.307739] failed to power up DHD generic adapter, 0 retry left
Mar 23 06:27:17 localhost kernel: [ 6.323836] failed to power up DHD generic adapter, max retry reached**
Mar 23 06:27:17 localhost kernel: [ 7.170420] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 7.170438] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 7.170446] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 7.170453] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 7.170460] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:17 localhost kernel: [ 7.170467] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998049] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998067] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998075] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998082] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998088] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
Mar 23 06:27:19 localhost kernel: [ 8.998095] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
RP64 noob - by ziibii88 - 03-16-2019, 12:49 AM
RE: RP64 noob - by Mrfixit2001 - 03-16-2019, 08:06 AM
RE: RP64 noob - by ziibii88 - 03-16-2019, 10:11 PM
RE: RP64 noob - by Luke - 03-17-2019, 03:36 AM
RE: Feature Complete Debian Desktop Release - by siggi - 03-23-2019, 01:01 AM
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,474 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 2,226 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,563 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 4,626 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 5,474 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 13,106 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,424 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,151 09-30-2021, 11:54 AM
Last Post: publiclewdness
