Using ESP32 as WiFi and Bluetooth Module
(03-01-2019, 01:34 PM)psychedup Wrote:
(03-01-2019, 01:00 AM)shripal17 Wrote: Is there any way I can use the Espressif's ESP32 Module as only WiFi and Bluetooth Module for Rock64 using the GPIO Pins/Interface (e.g. UART/SPI/I2C)?
I can't find any references which would allow this functionality. All I could find are code examples for using ESP32 as standalone microcontroller
My goal is to use ESP32 as WiFi and Bluetooth Module on Android
At the hardware level I imagine that ought to be possible, but depending on what OS you want to run, you would need drivers for that would support such a configuration. I did a quick search and didn't find any.
I asked the same question on ESP32 Forum, they said using AT Commands would be the best option. I would write the drivers for AT Commands for Android
The AT commands can only be used for controlling/commanding the ESP32 like listing WiFi stations, or connecting to one and so on...
But what about the data transfer like loading a website or downloading files from the internet?
RE: Using ESP32 as WiFi and Bluetooth Module - by shripal17 - 03-08-2019, 02:44 AM
  get wifi mt7601u mediatek usb dongle to work Johannes 0 4,150 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 14,858 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 31,801 05-13-2020, 05:03 PM
  low speed wifi pas059 4 7,701 05-13-2019, 12:09 PM
Last Post: pas059
  emmc module help default_user8 1 4,187 04-05-2019, 07:19 PM
Last Post: SirRyanTheGeek
  50 kb with RTL8188eu WIFI adapter Juice4 2 5,187 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 3,998 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 23,345 05-30-2018, 12:20 AM
Last Post: scalextrix
  Very disappointed with ROCK64 USB WIFI 802.11B/G/N Danielsan 0 3,052 04-23-2018, 09:51 AM
Last Post: Danielsan
  None of my Wifi modules work NicoD 7 12,632 04-05-2018, 02:53 PM
