manjaro and qemmu+kvm
Hi, im trying to install qemmu on pinebook using manjaro.
I see kernel has enabled KVM via dmesg, but when try to create qemmu image ovmf files arent installed.
Strit said Anarsoul is kernel maintainer of manjaro-arm for pinebook.
But some packages aren't on majaro, like this, https://aur.archlinux.org/packages/ovmf-aarch64/
Any tips to install correctly qemu+kvm on pinebook?
I found more problems with qemu on manjaro arm pinebook.
sudo systemctl status libvirtd
● libvirtd.service - Virtualization daemon
Loaded: loaded (/usr/lib/systemd/system/libvirtd.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2019-02-25 12:21:05 CET; 2min 5s ago
Docs: man:libvirtd(8)
https://libvirt.org
Main PID: 673 (libvirtd)
Tasks: 17 (limit: 32768)
Memory: 57.2M
CGroup: /system.slice/libvirtd.service
└─673 /usr/bin/libvirtd
Feb 25 12:21:12 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:21:58 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:21:59 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
Feb 25 12:22:06 manjaro-arm libvirtd[673]: this function is not supported by the connection driver: cannot detect host CPU model for aarch64 architecture
manjaro and qemmu+kvm - by erchache2000 - 02-25-2019, 04:53 AM
RE: manjaro and qemmu+kvm - by Surehand53 - 02-27-2019, 12:48 PM
RE: manjaro and qemmu+kvm - by Skywheel - 06-11-2019, 03:11 AM
Information Manjaro ARM for Pinebook erchache2000 88 112,934 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
  Plasma-wayland on Manjaro tophneal 2 6,097 09-01-2020, 06:48 AM
  Manjaro sway profile for pinebook e-minguez 3 5,333 07-21-2020, 03:25 PM
Last Post: jezek
  Manjaro instability DAMO238 6 9,385 10-17-2019, 12:55 PM
  Manjaro hangs on boot DAMO238 1 3,250 07-08-2019, 08:14 AM
Last Post: DAMO238
