RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64
#38
Many thanks to Mrfixit since I know a ton of work has gone into this!
I am having a problem where after Recalbox has been idle for an hour or so, it loses the wifi connection.  I have to go into Network Settings, turn Wifi off and then hit Close.  Then I go back into the menu and turn it back on and it works again (or I can just reboot and it will automatically connect).  My wifi signal is strong so I don't think that is the problem.  Is there a Linux command that I can run that will force it to periodically check the connection and keep it alive or any other ideas for how to fix this?  Thank you!
RE: RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64 - by km782 - 03-23-2020, 02:44 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,597 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,785 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 2,021 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 3,289 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,741 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,438 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,472 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 4,581 05-13-2023, 12:01 AM
Last Post: swan
