RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64
(03-21-2019, 05:02 AM)Mrfixit2001 Wrote: km782 - there should be a file named /etc/init.d/S98xboxone which runs on every boot. That file will run the code you found:
  echo 1 > /sys/module/bluetooth/parameters/disable_ertm
I suggest removing / forgetting all paired devices from bluez, rebooting, and then re-pairing.
Unfortunately, as Lukasz said, we don't have an xboxone controller to test, and we greatly appreciate your feedback and help testing that!
I've been playing around with it for the last few days.  I found that one of the problems I was having is the bluetooth signal coming from the Rockpro64 seems to be pretty weak.  I may look into getting a bluetooth USB adapter in the future but for the time being I was able to reposition the antennas and get the Xbox One controller to connect using the bluetoothctl utility.  It also reconnects automatically after a reboot.
Once connected, the controller works great in Emulation Station.  I can configure the buttons and they all are recognized correctly.  However, none of the buttons work in any of the emulators.  Only the D-Pad and left Joystick work.  Do you have any idea what could cause this?
I don't know if it matters but the controller is detected as "XBox Wireless Controller" when I connect it via bluetooth.  If I connect the same controller via USB it is detected as "MICROSOFT X-BOX ONE S PAD".  When it is connected via USB everything works fine both in Emulationstation and within the emulators.
Thanks again for the help!
RE: RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64 - by km782 - 04-01-2019, 08:04 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,597 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,819 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,071 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 2,021 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 3,290 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,746 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,441 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,556 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,769 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 4,589 05-13-2023, 12:01 AM
Last Post: swan
