RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64
(03-20-2019, 04:08 PM)Luke Wrote:
(03-20-2019, 10:59 AM)km782 Wrote: Does the "Additional fixes for Xbox One controllers" mean that they should work over Bluetooth or only USB?  Mine works fine when connected over USB but I am unable to pair it via Bluetooth.
Thank you so much for all of the hard work that has been put into this!
The Xbox One controller is literally the ONLY controller none of us had  to test (we tested all other controllers)... so you tell us.
The controller works great when connected via USB.
It won't pair via Bluetooth.  In emulationstation the controller is never found.
I found something online that said if you run:
echo 1 > /sys/module/bluetooth/parameters/disable_ertm
it will let you connect the controller.  After that the emulationstation will find the controller, listing it with the MAC address and "Xbox Wireless Controller" but as soon as you select it to pair it immediately says "Unable to Pair Controller."
When I log into the computer via SSH, using bluetoothctl I can get it to pair and trust but it won't connect:
Attempting to connect to 9C:AA:1BBig GrinF:B2:14
Failed to connect: org.bluez.Error.Failed
The package xpadneo (https://github.com/atar-axis/xpadneo) is supposed to connect the controller.  Any chance this could be added to recalbox?
Let me know if there is anything that you would like to me to try or any more information that would be helpful.  Thanks!
RE: RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64 - by km782 - 03-20-2019, 08:59 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,501 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 136,347 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,062 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 2,011 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 3,271 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,722 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,281 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,256 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,758 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 4,552 05-13-2023, 12:01 AM
Last Post: swan
