Fitting Rockpro64 inside Pinebook case
(02-19-2019, 11:37 AM)made2hack Wrote: Hi all,
Please note that I've not delved into the matter properly (ie read the specs or look at the sizes) yet. But, conceivably, do you think at first glance it might be possible to fit the Rockpro64 Board inside the bottom case of the Pinebook? 14" model.
Thanks and regards,
No. But you will be able to fit a Pinebook Pro mainboard into a 14" Pinebook chassis.
RE: Fitting Rockpro64 inside Pinebook case - by Luke - 02-19-2019, 11:39 AM
  DeskPi case alternative for ROCK64 v1k699 2 11,058 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 2,717 05-13-2025, 07:32 AM
  Looking for a good display for my RockPro64 RK3399 ziomario 0 1,334 11-09-2024, 10:13 AM
Last Post: ziomario
  7" LCD on RockPro64 spammycheese 1 2,813 03-10-2023, 04:05 PM
Last Post: peteressive
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 6,292 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 23,509 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 22,888 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 9,837 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 4,083 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 21,277 07-09-2019, 06:15 AM
Last Post: merwone
