02-11-2019, 04:00 PM
I should have added that a similar setup based on the same version of DietPi, but using a Raspberry and the special cable WDLabs provided to power the drive directly from the power supply instead via the USB port, has absolutely NO problem at all. Unfortunately, not only due to a lack of physical space, the same cable cannot be used with the Rock64 as it uses MicroUSB connectors and not the barrel ones.
