Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
#35
(04-02-2019, 10:46 AM)Neo2018 Wrote: Yes, unfortunately the energy consumption is high. And with today's energy price we probably too expensive.
No, it's not the end of the world, but it's always annoying and frustrating when it does not work.
Thanks for the great support!
You welcome,
The majority of this tools use the SCSI layer, also because if your disk is in StandBy, it has big probability to not wake up, with certain commands..
On contrary using the Block Device driver, they will wake always..and 1 load/Unload cycle was waisted, and energy also..
Seagate guys, assured me that it should work for sure, they  have tested virtually almost all options..
Now I feel myself badly...  Blush
I found some spare time today,
And I started playing around with some adaptors, none worked. on Rockpro64.
And so I checked( what I though was right, from the beginning.. the SCSI driver...it was not ) :
root@rockpro64:~# zcat /proc/config.gz |grep CHR_DEV_SG
# CONFIG_CHR_DEV_SG is not set
I though that the SCSI Generic driver was something that for sure was built on kernel..
Or as a module...
That is the problem..
You need a kernel module 'sg' driver for your kernel version...
I am sorry I haven't checked it before..I though it was for sure built-in...  Huh
RE: Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities - by tuxd3v - 04-02-2019, 11:29 AM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 18,721 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 6,304 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 69,449 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 5,474 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 7,399 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 34,402 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 4,357 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 4,297 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 5,065 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 13,570 07-31-2018, 12:40 PM
Last Post: dukla2000
