Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
#28
(03-18-2019, 05:50 AM)tuxd3v Wrote: The APM mode 127, sends the disk in standby, relatively fast..
I don't know if you remember that I asked you about if you had something else Running from the IronWolf disk?
The hard disk is used only for data> music, movies, data.
OS runs on the eMMC 64 GB.
(03-18-2019, 05:50 AM)tuxd3v Wrote: If a disk is sleeping, and you issue some monitoring command on Him, it will wakeup, and I think this his the behaviour you are experiencing..
Maybe OMV is doing monitoring too much..
Try to use its corresponding SCSI counterpart, /dev/sgx, this can work for some commands, and doesn't usually wakeup the disks, but its more limited than query the /dev/sdX..
Maybe this is the problem..
For the test, I have the hard drive set to 128, SMART completely disabled. > No effect / same problem.
Hard disk changes to standby mode after 2 minutes.
OMV Forum report
RE: Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities - by Neo2018 - 03-19-2019, 05:18 AM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 18,721 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 6,304 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 69,449 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 5,474 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 7,399 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 34,402 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 4,357 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 4,297 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 5,065 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 13,570 07-31-2018, 12:40 PM
Last Post: dukla2000
