Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
(03-02-2019, 01:40 PM)tuxd3v Wrote: Assuming the binaries are ok,
My best bet is that maybe you need to insert the disks in a real Sata port, for example, to enable Power Up in StandBy and SpinUp Control..
I use ROCKPro64 PCI-e to Dual SATA-II Interface Card for HDD disk.
How or where should I do this?
(03-02-2019, 01:01 PM)tuxd3v Wrote: 1) The compiled Binaries have some problem.
2) The pcie controllers in the middle doesn't let Seagate Firmware Commands pass-trough, and blocks them..
Assuming case 1) its ok..
Going with option
 2) "Pass-Trough"
Probably Pcie controller is blocking the commands that openSeaChest is sending to disks..
Probably it doesn't understand them as they are Seagate Own Command specific, and reject them..
Maybe blocked hdparm, OMV or S.M.A.R.T to?
RE: Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities - by Neo2018 - 03-02-2019, 01:52 PM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 23,518 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 8,200 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 76,050 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 6,755 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 8,323 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 39,441 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 4,776 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 4,779 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 5,545 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 14,920 07-31-2018, 12:40 PM
Last Post: dukla2000
