No Boot, Red Green and White flash at 1 sec intervals
(01-24-2019, 11:46 PM)wesleykonrad Wrote: I have the Rock 64 booting off of a dietpi image on a 16gb eMMC.  It was working fine for a while.  Now it is has all three LED's, Green, Red and White, at 3 second intervals.  I tried removing the eMMC and booting off of a SD, it doesn't seem to go through any boot process.  I tried connecting a serial console connection but it gives me nothing (no garbage, just nothing)  The serial connection worked in the past.
Anybody know what that means?
I contacted support, here was their response:
1. Please advise your power supply rating, make sure is 5V 3A type. Under power can cause board runs in unstable condition
2. Please make sure that no USB device has plug into USB port on first try. Some power leaking USB hub can prevent ROCK64 to boot up.
3. If there is not USB drive detected, please unplug other cable such as HDMI and Ethernet cable, plug in power plug and observe whether the blinking still happen.
4. if blink still happen, please check whether there is any hot spot (temperature that reach finger burn stage). If there is extremely hot spot on the board, your board may be turns bad.
5. If your board don't have hot spot, another potential issue is the OS build on your microSD card corrupted. Please rebuild your microSD card (if possible, using another card) and check whether able to boot up properly.
I have tried all these steps.  When I reported that back to support they issued me an RMA
RE: No Boot, Red Green and White flash at 1 sec intervals - by wesleykonrad - 01-28-2019, 11:54 PM
  Rock64 won't boot luminosity7 10 4,062 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 323 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,524 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,074 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,048 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 2,639 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,552 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,530 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,642 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 15,317 08-27-2020, 01:44 PM
Last Post: globaltree
