Clusterboard Guide
(03-15-2019, 10:48 AM)BryanS Wrote: Does the clusterboard itself need an IP address, or is it just a dumb switch that passes the addresses of the modules through? Is there something special you need to do to the address on the modules or the clusterboard itself to make networking work?
I've set static IP addresses on my modules but I don't get any outside access. I see the yellow LEDs flickering indicating that I do have something incoming...
It is a dumb switch.  Best thing to do would be to let them pull down DHCP and check the DHCP server for what addresses have been assigned.  Those will have MAC addresses associated with them and you can use those to set up your DHCP server to assign static addresses.
Clusterboard Guide - by AZClusterboard - 01-20-2019, 09:48 PM
RE: Clusterboard Guide - by BryanS - 03-15-2019, 10:48 AM
RE: Clusterboard Guide - by AZClusterboard - 03-15-2019, 05:14 PM
RE: Clusterboard Guide - by billotronic - 03-16-2019, 07:28 AM
RE: Clusterboard Guide - by AZClusterboard - 03-16-2019, 05:10 PM
RE: Clusterboard Guide - by AZClusterboard - 03-20-2019, 10:27 AM
RE: Clusterboard Guide - by tllim - 03-25-2019, 10:41 PM
RE: Clusterboard Guide - by ykanello - 08-31-2019, 08:50 AM
RE: Clusterboard Guide - by timoc - 07-14-2020, 10:07 AM
RE: Clusterboard Guide - by poVoq - 04-06-2021, 06:32 AM
  Managed Ethernet switch on the Clusterboard dsimic 6 5,440 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 5,886 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 1,635 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 12,604 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 5,267 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 2,086 05-25-2021, 10:28 AM
Last Post: TechDragon
Brick Clusterboard CAD drawings TeaPack 1 3,836 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 7,351 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 6,228 08-15-2020, 07:31 AM
Last Post: poVoq
  Clusterboard <-> Baseboard pinout mappings curtyc 1 5,513 08-08-2020, 06:13 PM
Last Post: lbruno
