OpenBSD on Pinebook 1080p?
#21
(02-19-2020, 09:50 AM)ab1jx Wrote: I'm on a Pinebook Pro, Rockchip, 14 inch 1920x1080, delivered 1/13/2020, BTW, not 11 inch or older models.  So there both old and new models in both sizes I think.  This is closely related to a Rock64 Pro I think, but it's Rockchip, not Allwinner.
Oh you're right. I didn't realize the PBP had a different chip. I have a Pinebook from 2018 and I think @elewarr has this one. That last model is what this thread was originally about (but I found it worked for mine too). Sorry for misleading you.
u-boot-aarch64 contains
$ ls /usr/local/share/u-boot/rockpro64-rk3399/*
/usr/local/share/u-boot/rockpro64-rk3399/idbloader.img             /usr/local/share/u-boot/rockpro64-rk3399/u-boot.img
/usr/local/share/u-boot/rockpro64-rk3399/u-boot                    /usr/local/share/u-boot/rockpro64-rk3399/u-boot.itb
/usr/local/share/u-boot/rockpro64-rk3399/u-boot.bin
so I imagine you could replace the u-boot with one of those. I did find https://github.com/sigmaris/u-boot/wiki/...t-sequence which gives different addresses to install to. I can't help test anymore.
This is probably a question for misc@openbsd.org at this point. I searched the archives and there's some talk about the pinebook (here) but nothing about the Pinebook Pro.
I still think you should double-check that you're writing to the correct disk, too. Try downloading one of these https://wiki.pine64.org/index.php/Pinebo...re_Release and seeing if that'll boot, just to double-check the details. OpenBSD on pine is still a work in progress -- well, so is everything, but obviously Linux has more support and testing.
From that boot-sequence page, I think you might be able to do this (on a Linux machine):
wget https://cdn.openbsd.org/pub/OpenBSD/6.6/packages/amd64/u-boot-aarch64-2019.10.tgz
tar -zxf u-boot-aarch64-2019.10.tgz
sudo dd if=share/u-boot/rockpro64-rk3399/idbloader.img of=/dev/mmcblk1 bs=512 seek=64
sudo dd if=share/u-boot/rockpro64-rk3399/u-boot.img of=/dev/mmcblk1 bs=512 seek=16384
sync
This is comparable to these NetBSD instructions:
NetBSD-ARM Wrote:Download or build arm64.img (64-bit) from NetBSD 9.0 or later
Write the image to disk: dd if=arm64.img of=/dev/rld0d bs=1m conv=sync
Install a board-specific U-Boot from pkgsrc to the SD card dd if=/usr/pkg/share/u-boot/<boardname>/rksd_loader.img of=/dev/rld0d seek=64 conv=sync
Put the sdcard into the PBP and if it works you should see OpenBSD's branch of u-boot booting. Let us know how it goes!
If you get that far then you can adapt the install instructions for the Pinebook.
In fact I downloaded the vetted NetBSD image from http://www.armbsd.org/arm/ and inspected it:
$ wget http://www.armbsd.org/arm/netbsd-9/202002191440Z/NetBSD-evbarm-aarch64-202002191440Z-rockpro64.img.gz
$ gunzip NetBSD-evbarm-aarch64-202002191440Z-rockpro64.img.gz
$ hexdump -C NetBSD-evbarm-aarch64-202002191440Z-rockpro64.img
[.. snipped ..]
00008000  3b 8c dc fc be 9f 9d 51  eb 30 34 ce 24 51 1f 98  |;......Q.04.$Q..|
00008010  ff 0c f2 36 05 50 c8 bb  3f ec dd bd 06 85 fa b7  |...6.P..?.......|
00008020  b3 ab 6a ea c8 68 e0 08  ad 9d 6f 9c 3c 98 b0 8c  |..j..h....o.<...|
00008030  45 13 54 1c 1d 1b 1f 15  a7 f1 f0 0b e3 4e 0c c7  |E.T..........N..|
00008040  60 96 01 6a b5 f0 e2 c1  50 c6 24 9e 12 f7 58 8e  |`..j....P.$...X.|
00008050  40 b9 b7 be 8b fa 25 dd  74 d7 6f 59 46 7e 13 41  |@.....%.t.oYF~.A|
00008060  ee fd f5 91 39 bc 74 95  25 3c 1a e1 f1 57 30 05  |....9.t.%<...W0.|
00008070  ca f8 72 9a 1b e6 9d 26  35 5d 81 2b 2b 93 bd 01  |..r....&5].++...|
00008080  3a 54 0c a1 4b 11 06 98  a1 91 19 4a 4e 92 30 1a  |:T..K......JN.0.|
00008090  f2 b2 d5 ae 59 6c 9e 96  fd f4 ff a4 88 e3 9f 87  |....Yl..........|
000080a0  49 6c 3a 76 6d 3d 1a ac  1e 77 0a 5e ff 92 52 61  |Il:vm=...w.^..Ra|
000080b0  19 ff 74 96 ee 13 93 7a  e0 b9 f0 1b 51 38 b3 8d  |..t....z....Q8..|
000080c0  2f 59 87 02 65 c1 88 6b  4c 21 aa 7b 16 d5 50 ce  |/Y..e..kL!.{..P.|
000080d0  37 80 a4 1f 46 df bd b0  d9 65 8f e1 15 ce 08 0f  |7...F....e......|
000080e0  7c ee 5a 0c 61 50 3c 90  bf 79 1a bf 05 96 b0 61  ||.Z.aP<..y.....a|
000080f0  eb ed 62 53 4b 3a ee a4  aa 77 95 df e9 e7 44 fb  |..bSK:...w....D.|
00008100  2d f8 ba 7e b2 1e e0 04  ea ea d2 d7 61 f9 90 92  |-..~........a...|
00008110  88 e3 07 b6 5a 8f 9b 4e  4f 9e f9 c8 38 d9 11 5d  |....Z..NO...8..]|
00008120  41 37 f4 dd 5b 78 47 95  8a ac f5 42 5d aa 0c 52  |A7..[xG....B]..R|
00008130  49 c8 0d 9d a7 32 2e d7  03 b1 41 95 49 50 2d 89  |I....2....A.IP-.|
00008140  27 5b 0d 0e 72 6f fa 0e  0b 70 bc 15 42 a2 26 cb  |'[..ro...p..B.&.|
00008150  d5 26 65 0c cb b1 ec 54  45 45 e5 39 d5 7b 77 ff  |.&e....TEE.9.{w.|
00008160  9b c0 c8 38 4e e5 6e 4a  bb 42 9f 43 d1 d0 5e 04  |...8N.nJ.B.C..^.|
00008170  78 0f 00 3e 06 bc 07 3c  c9 4d 2a 64 b9 43 77 cf  |x..>...<.M*d.Cw.|
00008180  93 d7 f8 68 00 38 b9 7b  e8 aa f3 8a 47 96 27 8b  |...h.8.{....G.'.|
00008190  44 45 c4 c4 ed e0 a1 26  02 6f dd 37 87 92 c6 01  |DE.....&.o.7....|
000081a0  03 14 a0 e6 aa 2b 6c da  e5 98 75 35 3a 2c bf cc  |.....+l...u5:,..|
000081b0  b5 27 62 5f d0 dc 2a 9b  d7 a2 4d d7 72 65 7a d1  |.'b_..*...M.rez.|
000081c0  17 3a 98 e7 3c 57 8e b6  a0 32 34 c9 6e d1 ca cd  |.:..<W...24.n...|
000081d0  81 95 bd 6e 0e 84 5c a6  cb 0c 42 5f c8 16 e0 3e  |...n..\...B_...>|
000081e0  ac f3 32 8e 44 56 02 25  df cd af 1e 1d 36 59 b6  |..2.DV.%.....6Y.|
000081f0  44 58 d1 d5 ea 04 c3 6b  91 8d ff 93 8c 2c 27 45  |DX.....k.....,'E|
00008200  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
[.. snipped ..]
This is almost identical, except for two bytes on the second last line, to the *start* of OpenBSD's idbloader.img:
$ hexdump  -C /usr/local/share/u-boot/rockpro64-rk3399/idbloader.img
00000000  3b 8c dc fc be 9f 9d 51  eb 30 34 ce 24 51 1f 98  |;......Q.04.$Q..|
00000010  ff 0c f2 36 05 50 c8 bb  3f ec dd bd 06 85 fa b7  |...6.P..?.......|
00000020  b3 ab 6a ea c8 68 e0 08  ad 9d 6f 9c 3c 98 b0 8c  |..j..h....o.<...|
00000030  45 13 54 1c 1d 1b 1f 15  a7 f1 f0 0b e3 4e 0c c7  |E.T..........N..|
00000040  60 96 01 6a b5 f0 e2 c1  50 c6 24 9e 12 f7 58 8e  |`..j....P.$...X.|
00000050  40 b9 b7 be 8b fa 25 dd  74 d7 6f 59 46 7e 13 41  |@.....%.t.oYF~.A|
00000060  ee fd f5 91 39 bc 74 95  25 3c 1a e1 f1 57 30 05  |....9.t.%<...W0.|
00000070  ca f8 72 9a 1b e6 9d 26  35 5d 81 2b 2b 93 bd 01  |..r....&5].++...|
00000080  3a 54 0c a1 4b 11 06 98  a1 91 19 4a 4e 92 30 1a  |:T..K......JN.0.|
00000090  f2 b2 d5 ae 59 6c 9e 96  fd f4 ff a4 88 e3 9f 87  |....Yl..........|
000000a0  49 6c 3a 76 6d 3d 1a ac  1e 77 0a 5e ff 92 52 61  |Il:vm=...w.^..Ra|
000000b0  19 ff 74 96 ee 13 93 7a  e0 b9 f0 1b 51 38 b3 8d  |..t....z....Q8..|
000000c0  2f 59 87 02 65 c1 88 6b  4c 21 aa 7b 16 d5 50 ce  |/Y..e..kL!.{..P.|
000000d0  37 80 a4 1f 46 df bd b0  d9 65 8f e1 15 ce 08 0f  |7...F....e......|
000000e0  7c ee 5a 0c 61 50 3c 90  bf 79 1a bf 05 96 b0 61  ||.Z.aP<..y.....a|
000000f0  eb ed 62 53 4b 3a ee a4  aa 77 95 df e9 e7 44 fb  |..bSK:...w....D.|
00000100  2d f8 ba 7e b2 1e e0 04  ea ea d2 d7 61 f9 90 92  |-..~........a...|
00000110  88 e3 07 b6 5a 8f 9b 4e  4f 9e f9 c8 38 d9 11 5d  |....Z..NO...8..]|
00000120  41 37 f4 dd 5b 78 47 95  8a ac f5 42 5d aa 0c 52  |A7..[xG....B]..R|
00000130  49 c8 0d 9d a7 32 2e d7  03 b1 41 95 49 50 2d 89  |I....2....A.IP-.|
00000140  27 5b 0d 0e 72 6f fa 0e  0b 70 bc 15 42 a2 26 cb  |'[..ro...p..B.&.|
00000150  d5 26 65 0c cb b1 ec 54  45 45 e5 39 d5 7b 77 ff  |.&e....TEE.9.{w.|
00000160  9b c0 c8 38 4e e5 6e 4a  bb 42 9f 43 d1 d0 5e 04  |...8N.nJ.B.C..^.|
00000170  78 0f 00 3e 06 bc 07 3c  c9 4d 2a 64 b9 43 77 cf  |x..>...<.M*d.Cw.|
00000180  93 d7 f8 68 00 38 b9 7b  e8 aa f3 8a 47 96 27 8b  |...h.8.{....G.'.|
00000190  44 45 c4 c4 ed e0 a1 26  02 6f dd 37 87 92 c6 01  |DE.....&.o.7....|
000001a0  03 14 a0 e6 aa 2b 6c da  e5 98 75 35 3a 2c bf cc  |.....+l...u5:,..|
000001b0  b5 27 62 5f d0 dc 2a 9b  d7 a2 4d d7 72 65 7a d1  |.'b_..*...M.rez.|
000001c0  17 3a 98 e7 3c 57 8e b6  a0 32 34 c9 6e d1 ca cd  |.:..<W...24.n...|
000001d0  81 95 bd 6e 0e 84 5c a6  cb 0c 42 5f c8 16 e0 3e  |...n..\...B_...>|
000001e0  ac f3 32 8e 44 56 02 25  df cd af 1e 1d 36 59 b6  |..2.DV.%.....6Y.|
000001f0  44 58 d1 d5 ea 04 c3 6b  91 8d ef 93 9c 2c 27 45  |DX.....k.....,'E|
00000200  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
They diverge after that point but it's a good start.
OpenBSD on Pinebook 1080p? - by binholz - 01-17-2019, 10:10 AM
RE: OpenBSD on Pinebook 1080p? - by heywire - 01-17-2019, 02:57 PM
RE: OpenBSD on Pinebook 1080p? - by cambridgei - 05-24-2019, 07:45 AM
RE: OpenBSD on Pinebook 1080p? - by ninefathom - 05-30-2019, 06:01 PM
RE: OpenBSD on Pinebook 1080p? - by michaelj - 10-07-2019, 03:00 PM
RE: OpenBSD on Pinebook 1080p? - by elewarr - 10-20-2019, 01:05 PM
RE: OpenBSD on Pinebook 1080p? - by joancatala - 10-21-2019, 11:55 AM
RE: OpenBSD on Pinebook 1080p? - by elewarr - 11-04-2019, 06:17 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 12-20-2019, 06:19 AM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 12-20-2019, 07:51 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-18-2020, 11:45 AM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-18-2020, 02:20 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-18-2020, 05:53 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-18-2020, 09:18 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-18-2020, 09:00 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-18-2020, 09:47 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-18-2020, 10:01 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-19-2020, 12:18 AM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-19-2020, 01:34 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-19-2020, 09:50 AM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-20-2020, 10:02 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-22-2020, 05:54 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 02-22-2020, 08:06 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 02-22-2020, 09:25 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 03-15-2020, 05:16 PM
RE: OpenBSD on Pinebook 1080p? - by rogerroger - 03-16-2020, 12:59 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 03-16-2020, 11:54 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 03-16-2020, 10:01 PM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 03-17-2020, 07:59 AM
RE: OpenBSD on Pinebook 1080p? - by ab1jx - 03-18-2020, 06:42 AM
Thumbs Up NetBSD for Pinebook Luke 20 36,151 10-21-2020, 03:39 AM
Last Post: rckt
  FreeBSD for Pinebook e-minguez 4 9,623 10-14-2020, 05:12 PM
Last Post: zer0sig
Question OpenBSD 6.7 on Pinebook 1080p SKG 4 7,995 05-25-2020, 08:15 AM
Last Post: SKG
  OpenBSD on Pinebook - improving user experience elewarr 15 18,925 12-20-2019, 06:57 PM
Last Post: rogerroger
