Rock64 OMV help needed
For starters it would be good to get some logs and more details. Good that the scenario is easy to replicate because its reoccurring.
For starters I suggest giving your omv user ssh access to omv and / or enabling root ssh access via the OMV WebGUI.
Here are a few questions that could provide some context:
1) how exactly is the HDD externally powered ?
2) what does it mean exactly that the board becomes unresponsive? (does the power LED stay on? what about the LED indicators ? the Ethernet LEDs ?)
3) if you already have enabled ssh access, have you tried to ssh into the board when 'it becomes non-responsive' ?
4) are you sure that your router doesn't change the boards IP?
Now, its possible that there are some hints in the existing logs which can be found here:
OMV WebGUI -> Diagnostics -> system log
From here grab syslog ; messages ; S.M.A.R.T and pastebin the logs in this thread.
When you encounter the same issue again, try and see if you can ssh into the board. If you can, then do grab dmesg and pastebin it here together with the previously mentioned logs.
Rock64 OMV help needed - by Osobigg - 01-16-2019, 12:14 AM
RE: Rock64 OMV help needed - by Luke - 01-16-2019, 06:09 AM
Rock64 OMV help needed - by helsinki92 - 01-18-2019, 06:32 AM
RE: Rock64 OMV help needed - by rockypine - 01-22-2019, 09:50 AM
Rock64 OMV help needed - by helsinki92 - 02-10-2019, 08:24 PM
RE: Rock64 OMV help needed - by Osobigg - 02-11-2019, 11:45 AM
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 218 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 8,176 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 5,603 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 4,033 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 313 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,849 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,472 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,053 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 738 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 939 10-07-2022, 07:50 PM
Last Post: rookie_267
