Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
#75
In the title and the readme for my kernel repo I list the boards which I have tested the kernel on. These are the only boards which I can confirm it works for and therefore the only boards I support. Extlinux can be pulled from my debian release's boot partition easily enough, but if you aren't able to grab it then I can pastebin it when I'm back at my environment. And I *think* you can just add the name of the DTB at the end of your make command in order to compile just that specific device tree (ex: make arch=arm64 rk3399-rockpro64.dtb), but I'll need to confirm if that's correct. I use a buildroot toolchain in my dev environment to compile and keep track of my patches and system configs, and it always only compiles a single DTB. So it's absolutely possible, yes.
RE: Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by Mrfixit2001 - 03-06-2019, 08:56 AM
  RK3399 PCIe enumeration jhadd 0 2,025 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,454 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,691 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,030 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,311 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,558 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,043 02-17-2022, 12:10 PM
Last Post: flounder
