Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
#46
I'm sorry to report this build is still not playing well with my PCIe x4 Sata card.
I can boot into the OS most of the time, but a warm reboot is hit & mis. My monitor becomes active but nothing is shown on it.
When I can boot into the os, lspci shows:
00:00.0 PCI bridge: Device 1d87:0100
01:00.0 PCI bridge: Pericom Semiconductor Device 2608
02:01.0 PCI bridge: Pericom Semiconductor Device 2608
02:02.0 PCI bridge: Pericom Semiconductor Device 2608
02:03.0 PCI bridge: Pericom Semiconductor Device 2608
02:04.0 PCI bridge: Pericom Semiconductor Device 2608
03:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
04:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
05:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
06:00.0 SATA controller: Marvell Technology Group Ltd. Device 9215 (rev 11)
I can see the one harddrive I attached to the board, and can mount the partition and do read/write operations.
However the sata card stil gets extremely hot, after two minutes the four chipset chips got over 80 degrees celsius. I switched the board off because I was afraid I was going to damage the card. The card has 4 marvel 9215 chips on it, each able of controlling 4 sata disks (https://www.amazon.com/IO-Crest-Controll...B00XI4OL82)
In dmesg I can see entries like below, perhaps this has something to do with it?
[    0.230078] vcc12v_pcie: supplied by dc_12v
[    0.230086] dc_12v: could not add device link regulator.8 err -2
[    0.230122] vcc12v_pcie: 12000 mV
[    0.230280] reg-fixed-voltage vcc1v8-sdio: Looking up vin-supply from device tree
[    0.230296] vcc1v8_sdio: unable to resolve supply
[    0.230303] reg-fixed-voltage vcc1v8-wifi: Looking up vin-supply from device tree
[    0.230317] vcc1v8_wifi: unable to resolve supply
[    0.230326] reg-fixed-voltage vcc12v-pcie-regulator: vcc12v_pcie supplying 12000000uV
[    0.230380] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc3v3-pcie-regulator[0]'
[    0.230395] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.230429] vcc3v3_pcie: supplied by vcc3v3_sys
[    0.230437] vcc3v3_sys: could not add device link regulator.9 err -2
[    0.230462] vcc3v3_pcie: 3300 mV
Attached is my dmesg.
.txt   output.txt (Size: 98.81 KB / Downloads: 572)
RE: Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by MisterA - 02-24-2019, 10:17 AM
  RK3399 PCIe enumeration jhadd 0 2,025 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,454 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,691 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,030 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,311 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,558 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,043 02-17-2022, 12:10 PM
Last Post: flounder
