Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
#26
@mrfixit: First off: Thank you for your work!!!
I wanted to ask you how you get the SDIO WIFI module to work. I am running Arch Linux now and i tried to boot your kernel but it did not work (seems like some kind of firmware was not found). I also tried to enable all SDIO related options in kernel-config and built it against Mainline 4.19. Building did work but WIFI cannot be detected. I am asking you to either share your trick to get Linux to detect SDIO WIFI or alternatively, as open source programming generally would suggest, to share the complete patchset and/or config with the community.
RE: Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by NoDiskNoFun - 01-31-2019, 01:54 PM
  RK3399 PCIe enumeration jhadd 0 2,021 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,459 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,451 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,667 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,820 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,014 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,306 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,549 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,035 02-17-2022, 12:10 PM
Last Post: flounder
