Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
#23
(01-24-2019, 08:55 AM)MisterA Wrote: I tested my pcie sata controller based on a Marvel 9215 chipset, but it fails to initialize successfully.
The same for me with the RockPro64 PCIe Dual SATA card (https://www.pine64.org/?product=rockpro6...rface-card):
# dmesg | grep -i pci
                  PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.127759] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.220531] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    0.220577] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.220623] vcc3v3_pcie: supplied by dc_12v
[    0.220674] vcc3v3_pcie: 3300 mV
[    0.220827] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    0.280807] PCI: CLS 0 bytes, default 64
[    0.414935] ehci-pci: EHCI PCI platform driver
[    0.897651] vcc3v3_pcie: disabling
[    1.837381] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    1.837397] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    1.839113] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    1.839128] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    1.839185] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    1.839472] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    1.839673] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    1.839684] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    1.839721] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    1.839727] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    1.839735] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    1.839749] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.839827] rockchip-pcie f8000000.pcie: invalid power supply
[    2.339880] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.340080] rockchip-pcie: probe of f8000000.pcie failed with error -110
RE: Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by rosseba - 01-26-2019, 12:04 PM
  RK3399 PCIe enumeration jhadd 0 2,021 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,459 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,451 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,667 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,820 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,014 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,306 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,549 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,035 02-17-2022, 12:10 PM
Last Post: flounder
