Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
Nice,but on my rp64 v2.1 2GB i don't have pcie.
pastebin
root@localhost:/home/rock# lspci -nn
root@localhost:/home/rock# lspci -vvv
Edit:
Uuupps, after reboot i got this.
00:00.0 PCI bridge: Device 1d87:0100 (prog-if 00 [Normal decode])
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort+ <MAbort+ >SERR+ <PERR+ INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 244
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 00000000-00000fff
    Memory behind bridge: fa000000-fa0fffff
    Prefetchable memory behind bridge: 00000000-000fffff
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
        PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Capabilities: [80] Power Management version 3
        Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
        Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME+
    Capabilities: [90] MSI: Enable+ Count=1/1 Maskable+ 64bit+
        Address: 00000000fee30040  Data: 0000
        Masking: 00000000  Pending: 00000000
    Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
        Vector table: BAR=0 offset=00000000
        PBA: BAR=0 offset=00000008
    Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00
        DevCap:    MaxPayload 256 bytes, PhantFunc 0
            ExtTag- RBE+
        DevCtl:    Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
            RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
            MaxPayload 128 bytes, MaxReadReq 512 bytes
        DevSta:    CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
        LnkCap:    Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
            ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
        LnkCtl:    ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
            ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt+
        LnkSta:    Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
        SltCap:    AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
            Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
        SltCtl:    Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
            Control: AttnInd Off, PwrInd Off, Power+ Interlock-
        SltSta:    Status: AttnBtn- PowerFlt- MRL+ CmdCplt- PresDet- Interlock-
            Changed: MRL- PresDet- LinkState-
        RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
        RootCap: CRSVisible-
        RootSta: PME ReqID 0000, PMEStatus- PMEPending-
        DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via message ARIFwd+
        DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
        LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
             Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
             Compliance De-emphasis: -6dB
        LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
             EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
    Capabilities: [100 v2] Advanced Error Reporting
        UESta:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UEMsk:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UESvrt:    DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
        CESta:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
        CEMsk:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
        AERCap:    First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
    Capabilities: [274 v1] Transaction Processing Hints
        Interrupt vector mode supported
        Device specific mode supported
        Steering table in TPH capability structure
    Kernel driver in use: pcieport
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a804 (prog-if 02 [NVM Express])
    Subsystem: Samsung Electronics Co Ltd Device a801
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 243
    Region 0: Memory at fa000000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: [40] Power Management version 3
        Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
    Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Address: 0000000000000000  Data: 0000
    Capabilities: [70] Express (v2) Endpoint, MSI 00
        DevCap:    MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
            ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
        DevCtl:    Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
            RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
        DevSta:    CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
        LnkCap:    Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
            ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
            ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
        LnkSta:    Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
        LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
    Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
        Vector table: BAR=0 offset=00003000
        PBA: BAR=0 offset=00002000
    Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
    Capabilities: [158 v1] Power Budgeting <?>
    Capabilities: [168 v1] #19
    Capabilities: [188 v1] Latency Tolerance Reporting
        Max snoop latency: 0ns
        Max no snoop latency: 0ns
    Capabilities: [190 v1] L1 PM Substates
        L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
              PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
        L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
               T_CommonMode=0us LTR1.2_Threshold=0ns
        L1SubCtl2: T_PwrOn=10us
    Kernel driver in use: nvme
Nice Smile
Now i will test wlan
Quote:root@localhost:/home/rock# iw wlan0 info
Interface wlan0
    ifindex 3
    wdev 0x1
    addr ac:83:f3:e6:1f:b2
    type managed
    wiphy 0
    txpower 31.00 dBm
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
RE: Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by Bullet64 - 01-15-2019, 01:30 PM
  RK3399 PCIe enumeration jhadd 0 268 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,318 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,286 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 550 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 2,102 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,342 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,177 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 1,294 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,412 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,027 02-17-2022, 12:10 PM
Last Post: flounder
