Assembling the premium aluminum case
(05-23-2021, 12:22 PM)CounterPillow Wrote:
(05-23-2021, 10:27 AM)jahway603 Wrote: Hi,
I am having trouble with what appears to be a defective premium aluminum case. Once the Rock64 is mounted, the case top does not line up with the "closing" screws. Has anyone else had this issue?
I've had the problem that the case doesn't close due to the board being pulled too low by fully tightened screws, and then not clearing the cutout holes for the HDMI, power and 3.5mm. Try to loosen the screws on that side such that they are only held in but the board has some wiggle room. Then when mounting the top cover, ensure the cutouts for those three ports clear the board correctly. Basically, leave it a bit floppy on one side.
Thank you for this, and I wish that were the same exact problem I was having, but I am having a different issue. Also, the Pine64 support staff is having trouble understanding the problem, even with photos and videos. Their last instructions to me with this defective case would actually snap my Rock64 PCB board, so I refuse to do that and they refuse to send a non-defective case. Since Pine64 support is not being co-operative, I now am asking the community for help. Thanks.
The image of the problem is too large for the forum, but I was able to compress it, so it is attached in the next post.
RE: Assembling the premium aluminum case - by jahway603 - 05-24-2021, 01:55 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 619 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,517 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,505 03-04-2022, 06:56 AM
Last Post: killor
Heart Best quick/easy way to control case fan speed? idillicah 4 5,993 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,956 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,065 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,890 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 3,746 02-20-2019, 01:27 AM
Last Post: made2hack
  Raspberry Pi OneNineDesign Case "Mod" MichaelRock 2 3,817 06-20-2018, 04:23 PM
  Is recommended to buy the case? enreador 1 2,862 05-03-2018, 03:55 PM
Last Post: evilbunny
