Tutorial:How to Configure ATS Fan control
#19
(02-05-2019, 02:01 PM)Neo2018 Wrote: [ENGLISH/GERMANY]
After a long wait and lack of time, I managed to install the second 80mm fan.
Here are a few pictures of construction together.
Nach langen warten und Zeitmangel habe ich es geschafft den zweiten 80mm Lüfter einzubauen.
Hier ein Paar Bilder von zusammen Bau.
I decided to place the sensor directly on the HDD because it gives off the most heat. When using the HDD, we reached a temperature of about 40°C quickly. Standard temperature is around 35°C, so it was important for me to keep the temperature below 40°C when using the HDD.
Ich habe entschieden den Sensor direkt auf die HDD zu platzieren, weil sie am meisten Wärme abgibt. Bei Einsatz der HDD wir eine Temperatur von ca. 40°C  schnell erreicht. Standard Temperatur ist bei ca. 35°C deshalb war mir wicht, bei Einsatz der HDD die Temperatur unter 40°C zu halten.
Zum Sensor Test To the sensor test - KSD9700 / 250V 5A 40°C / ON 40°C  OFF 29°C
Woow, very nice setup!!  Shy
I noticed that you are using Seagate IronWolf disks..
Those cat handle a max temp of 70C, WesternDigital max out at 60C..
I also have IronWolfs in my setup..
I made a tutorial that you will need for Seagate disks:
https://forum.pine64.org/showthread.php?tid=7137
After you have the tools installed, in that tutorial:
1) Enable Power UIn Standby( to use less current at startup..)
# Its a persistent feature
# No Power Cycle required
openSeaChest_Configure --device /dev/sdX --puisFeature enable
2) Enable Low Current SpinUp
# Its a persistent Feature
# Requires a Power Cycle( REBOOT )
openSeaChest_Configure --device /dev/sdX --lowCurrentSpinup enable
Thanks for sharing
RE: Tutorial:How to Configure ATS Fan control - by tuxd3v - 02-06-2019, 07:27 AM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 18,659 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 6,296 01-17-2021, 11:33 AM
  Serial Connection Tutorial: FTDI 232RL hmuller 0 5,462 10-23-2020, 11:56 AM
Last Post: hmuller
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 34,300 06-19-2019, 04:40 AM
Last Post: Neo2018
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 106,976 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 4,294 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 5,059 11-06-2018, 01:03 PM
Last Post: tuxd3v
