Tutorial:How to Configure ATS Fan control
(12-14-2018, 04:16 AM)tuxd3v Wrote: 2) If you have, the CPU processing a  lot:
    You would need to have a conector that will do,1 conector -> to 2 power derivation, connected to Conector 23.
    In this way,
    You can have power to disks, and power to  NASFan, but no control of NasFan, ON/OFF, etc, Fan will be always at Max speed
   To Control NasFan in this situation, you will need one of the options:
      2a) The romtorwator, solution of a thermostat, or other identical..
Thanks for the complete education, helped me a lot.
I will probably use KSD9700 40-NO, it seems to me the best and fastest solution.
It is a real pity that it is not immediately an extra plug for NasCase is provided.
I will report who I installed it.
Thank you.
RE: Tutorial:How to Configure ATS Fan control - by Neo2018 - 12-14-2018, 11:47 AM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 9,677 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,361 01-17-2021, 11:33 AM
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,192 10-23-2020, 11:56 AM
Last Post: hmuller
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 23,910 06-19-2019, 04:40 AM
Last Post: Neo2018
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 75,398 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,716 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,955 11-06-2018, 01:03 PM
Last Post: tuxd3v
