lighttpd
(04-19-2016, 01:30 PM)longsleep Wrote: Mhm works fine here. What image is that which you installed. I would suggest you do not use images from "somewhere" which do not even have a version number.
root@pine64-2gb:~# systemctl status lighttpd
● lighttpd.service - Lighttpd Daemon
  Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset:
  Active: active (running) since Tue 2016-04-19 19:27:05 UTC; 46s ago
Main PID: 20237 (lighttpd)
  CGroup: /system.slice/lighttpd.service
          └─20237 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Apr 19 19:27:04 pine64-2gb systemd[1]: Starting Lighttpd Daemon...
Apr 19 19:27:05 pine64-2gb lighttpd[20230]: Syntax OK
Apr 19 19:27:05 pine64-2gb systemd[1]: Started Lighttpd Daemon.
root@pine64-2gb:~# apt-get install lighttpd
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
 libnih1 libnl-route-3-200 seccomp ubuntu-core-security-apparmor
 ubuntu-core-security-seccomp ubuntu-core-security-utils ubuntu-snappy-cli
Use 'apt autoremove' to remove them.
The following additional packages will be installed:
 gamin libgamin0 libterm-readkey-perl libterm-readline-perl-perl spawn-fcgi
Suggested packages:
 rrdtool apache2-utils
The following NEW packages will be installed:
 gamin libgamin0 libterm-readkey-perl libterm-readline-perl-perl lighttpd
 spawn-fcgi
root@pine64-2gb:~# ps ax|grep lighttp
20237 ?        Ss     0:00 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
I am using the only image that works with the pine64 large memory version uploaded 04/17 from the Pine64.com web site link
Lighttpd failed with the error and rather than fight it and with the power of the pine64 I decided to go with Apache2 which works
(04-19-2016, 03:34 PM)jozzy answered Wrote: Bug ref. https://bugs.launchpad.net/ubuntu/+sourc...ug/1453463
You have to install gamin.
sudo apt-get install gamin
Thank You Jozzy I am loading it.  I am not sure if it will be needed as I will probably stay with Apache2
I will be replacing a Debial i386 power hungry server with the pine64 and it will run headless at my main
network star junction and will (hopefully) be recording about 15 network cameras to disk and acting as
a stream server.  So far all is good
Doug Wyman
Tiger Mountain Pacific Northwest USA
http://tigermountainsprings.net/
lighttpd - by wymand - 04-19-2016, 01:06 PM
RE: lighttpd - by longsleep - 04-19-2016, 01:30 PM
RE: lighttpd - by wymand - 04-19-2016, 04:11 PM
RE: lighttpd - by tkaiser - 04-20-2016, 03:06 AM
RE: lighttpd - by wymand - 04-20-2016, 09:13 AM
RE: lighttpd - by jozzy - 04-19-2016, 03:34 PM
