Armbian images available
#58
As always reporting on my finds...
Just tryed new desktop image of jammy in armbian and let me tell you, it just keeps getting better, they fixed (at least in my case) the weird bug that made you have to switch or unplug and plug back display so it worked after boot, so don't have to switch anymore display works all the way through load screen, also was able to install monkablyats docker with no issue and no hick ups works gr8 (wide vine for Netflix and Spotify) and Firefox does a gr8 job on videos with H264ify on 30fps, decided to install KDE plasma via tasksel and although it took a few runs Kongregate actually plays videos better then all other browsers (YouTube and straming/no widevine) it's more resource heavy but I'll pay the load for the extra eye candy.
If anything could go back xfce cause did notice a screen saver bug on KDE although it's turned off in settings keeps working worse case scenario I go back to xfce but still amazed with the progress and so happy to see that updates are still coming.
As always thanks for the hard work! my rp64 is glowing with eye candy now and what's more important it's working and doing all I want it to do better then ever. Thanks again, you guys rock!!
P. D.  did have trouble on first boot  if I had any usb device plugged on first run it wouldn't boot after first load (upgrade and update) issue dissapears but for those of you that want to try and your first boot isn't loading, might want to unplug all USB devices for first load...
Edit: Kongregate after a few debloating is doing 1080p in YouTube at a watchable quality 90/22000 drop rate in stats for nerds, so happy, Love you armbian❤️, also added psensor cause Temps don't show up in KDE and did not find any widget or gui for lm sensors
Armbian images available - by Luke - 12-04-2018, 05:34 AM
RE: Armbian images available - by y0sh - 12-04-2018, 09:51 AM
RE: Armbian images available - by NightCrawler504 - 12-04-2018, 02:31 PM
RE: Armbian images available - by NightCrawler504 - 12-04-2018, 04:22 PM
RE: Armbian images available - by battlenut - 01-09-2019, 07:01 AM
RE: Armbian images available - by NightCrawler504 - 01-13-2019, 01:08 AM
RE: Armbian images available - by pineadmin - 12-05-2018, 10:39 PM
RE: Armbian images available - by amator_1 - 12-07-2018, 09:03 AM
RE: Armbian images available - by QLEMAC - 01-04-2019, 07:22 PM
RE: Armbian images available - by lestat70 - 01-19-2019, 09:48 AM
RE: Armbian images available - by NightCrawler504 - 02-12-2019, 12:24 AM
RE: Armbian images available - by Luke - 02-12-2019, 05:13 AM
RE: Armbian images available - by festor89 - 02-12-2019, 07:22 AM
RE: Armbian images available - by Luke - 02-12-2019, 07:46 AM
RE: Armbian images available - by pineadmin - 05-31-2019, 02:01 AM
RE: Armbian images available - by NightCrawler504 - 06-08-2019, 02:19 AM
RE: Armbian images available - by Luke - 06-08-2019, 07:12 AM
RE: Armbian images available - by NightCrawler504 - 06-09-2019, 12:17 AM
RE: Armbian images available - by NightCrawler504 - 06-13-2019, 10:30 PM
RE: Armbian images available - by Luke - 06-14-2019, 12:38 AM
RE: Armbian images available - by igorp - 07-07-2019, 03:49 AM
RE: Armbian images available - by pineadmin - 07-10-2019, 01:34 AM
RE: Armbian images available - by pineadmin - 08-05-2019, 01:19 AM
RE: Armbian images available - by Wizzard - 10-29-2019, 02:18 AM
RE: Armbian images available - by Luke - 10-29-2019, 02:51 AM
RE: Armbian images available - by Wizzard - 10-29-2019, 02:59 AM
RE: Armbian images available - by Luke - 10-29-2019, 07:36 AM
RE: Armbian images available - by tllim - 10-30-2019, 08:33 PM
RE: Armbian images available - by Wizzard - 10-31-2019, 12:40 AM
RE: Armbian images available - by Luke - 10-31-2019, 07:36 AM
RE: Armbian images available - by Wizzard - 10-31-2019, 12:33 PM
RE: Armbian images available - by Luke - 10-31-2019, 02:55 PM
RE: Armbian images available - by Wizzard - 10-31-2019, 03:00 PM
RE: Armbian images available - by Luke - 10-31-2019, 03:01 PM
Armbian images available - by Wizzard - 10-31-2019, 03:10 PM
RE: Armbian images available - by balbes150 - 12-13-2019, 08:09 AM
RE: Armbian images available - by martinayotte - 12-13-2019, 08:24 AM
RE: Armbian images available - by balbes150 - 12-14-2019, 02:24 AM
RE: Armbian images available - by martinayotte - 12-14-2019, 07:35 AM
RE: Armbian images available - by balbes150 - 12-14-2019, 08:55 AM
RE: Armbian images available - by NightCrawler504 - 01-01-2020, 02:28 PM
RE: Armbian images available - by dukla2000 - 01-02-2020, 04:44 AM
RE: Armbian images available - by NightCrawler504 - 08-25-2020, 03:42 PM
RE: Armbian images available - by Wizzard - 09-17-2020, 04:49 AM
RE: Armbian images available - by NightCrawler504 - 12-28-2020, 04:14 AM
RE: Armbian images available - by NightCrawler504 - 02-08-2021, 10:34 PM
RE: Armbian images available - by bg002h - 03-23-2021, 06:02 PM
RE: Armbian images available - by TRS-80 - 03-23-2021, 09:45 PM
RE: Armbian images available - by bg002h - 03-24-2021, 04:44 PM
RE: Armbian images available - by bg002h - 03-25-2021, 02:12 PM
RE: Armbian images available - by bg002h - 03-25-2021, 10:41 PM
RE: Armbian images available - by MisterA - 04-22-2021, 09:58 AM
RE: Armbian images available - by Wizzard - 04-26-2021, 03:16 AM
RE: Armbian images available - by NightCrawler504 - 09-18-2021, 02:35 PM
RE: Armbian images available - by LMM - 09-19-2021, 01:50 AM
RE: Armbian images available - by TRS-80 - 09-28-2021, 02:46 PM
RE: Armbian images available - by bas-r - 04-19-2022, 02:28 AM
RE: Armbian images available - by NightCrawler504 - 04-22-2022, 12:26 AM
RE: Armbian images available - by TRS-80 - 04-30-2022, 03:43 PM
RE: Armbian images available - by NightCrawler504 - 08-03-2022, 05:13 PM
RE: Armbian images available - by Rocklobster - 08-04-2022, 06:56 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 156,440 08-17-2024, 02:32 PM
Last Post: taltamir
  Expose /dev/mali0 in armbian pedromiguel.sanchez 2 6,236 07-25-2022, 04:52 AM
Last Post: pedromiguel.sanchez
  Enable DSI/TD Ports on Armbian (jammy) dkebler 0 2,190 06-16-2022, 06:56 PM
Last Post: dkebler
  Armbian Jammy-Running fairly stable Rocklobster 0 2,436 05-04-2022, 01:00 PM
Last Post: Rocklobster
  Armbian is looking for maintainer for ROCKPro64 TRS-80 20 28,074 03-19-2022, 09:32 PM
Last Post: paralin1
  Armbian 22.02 Release Announcement TRS-80 0 2,555 02-28-2022, 05:08 PM
Last Post: TRS-80
  OpenMediaVault: link from wiki or Armbian? Goffi 0 2,419 02-10-2022, 03:57 AM
Last Post: Goffi
Bug Unreliable display in Armbian and Debian ksattic 3 6,400 11-17-2021, 05:42 AM
Last Post: PakoSt
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,017 10-29-2021, 11:15 AM
Last Post: TRS-80
  RockPro64 EDP in Armbian hannescam 2 4,740 10-15-2021, 09:07 AM
Last Post: hannescam
