RTL8812AU driver and connection issues
(12-03-2018, 07:28 PM)evilbunny Wrote:
(12-03-2018, 07:13 PM)pane Wrote: Thanks evilbunny I will recompile, I found that the output stream from power saving would spam the SSID key box in nmtui. What is your preferred process for connecting to networks? I have had limited success with nmtui - do you use wpa_supplicant or something else to reliably connect to networks?
I use network manager when I use a gui, but use /etc/network/interfaces.d/ on headless systems.
# cat /etc/network/interfaces.d/wlan0
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
# cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
       ssid="myaccesspoint"
       psk="mypassword"
Thanks for that evilbunny, your advice is always helpful - I consider my issue solved now, I will use wpa_supplicant then instead of nmtui as I am using headless debian
RTL8812AU driver and connection issues - by pane - 12-02-2018, 05:31 PM
RE: RTL8812AU driver and connection issues - by pane - 12-03-2018, 08:38 PM
  WIFI driver compilation wsk 1 4,015 11-01-2018, 12:21 AM
Last Post: wsk
  New github source for rtl8812au ! pytheas 2 6,145 03-07-2018, 02:55 AM
Last Post: pytheas
  Rock64 RTL8812AU dongle (from store) how to get working on Android? Nelly 4 8,807 02-07-2018, 10:28 PM
Last Post: varos16
  gpio driver porting from an r-pi3b gene83 9 14,849 12-02-2017, 03:44 AM
Last Post: xalius
