RTL8812AU driver and connection issues
(12-02-2018, 05:31 PM)pane Wrote: Hi All,
I managed to get the RTL8812AU driver working with the help of evilbunny. However, I am having connection issues, and power saving issues.
Power save issues seem to occur when the driver is not connecting to wifi. Fair enough, but when I use nmtui to connect to the wifi, my gui gets spammed with the "nolinked power save leave/enter" messages. It would be nice if there was a way to disable this either in startup or the driver itself.
Additionally, is there a process which works better than others for connections? I am unable to connect to networks 95% of the time with nmtui. Would anyone advocate for using wpa_supplicant or something else entirely for stable connections?
Thanks for your time
pane
You can disable the power saving mode by editing the Makefile and turning power saving off
CONFIG_POWER_SAVING = n
Then recompile etc.
RTL8812AU driver and connection issues - by pane - 12-02-2018, 05:31 PM
RE: RTL8812AU driver and connection issues - by evilbunny - 12-02-2018, 05:42 PM
  WIFI driver compilation wsk 1 2,860 11-01-2018, 12:21 AM
Last Post: wsk
  New github source for rtl8812au ! pytheas 2 4,426 03-07-2018, 02:55 AM
Last Post: pytheas
  Rock64 RTL8812AU dongle (from store) how to get working on Android? Nelly 4 6,288 02-07-2018, 10:28 PM
Last Post: varos16
  gpio driver porting from an r-pi3b gene83 9 10,551 12-02-2017, 03:44 AM
Last Post: xalius
