Ongoing HDMI limited compatability
#20
(04-20-2016, 06:24 AM)tkaiser Wrote:
(04-20-2016, 05:49 AM)rahlquist Wrote: cat: graphics/fb0/modes: No such file or directory
These are relative paths, most likely relative to /sys/class (don't know -- booted the Pine64 a few weeks ago the last time). You might succeed doing a 'find /sys -type d -name fb0' to know the prefix needed to chdir to or create absolute paths.
Thanks, when acting as 'smart hands' and troubleshooting using instructions from another person I tend to be terribly literal. Using the info you provided;
root@localhost:~# find /sys -type d -name fb0
/sys/devices/soc.0/1000000.disp/graphics/fb0
root@localhost:~# cat /sys/devices/soc.0/1000000.disp/graphics/fb0/modes
U:1920x1080p-0
Decided to get a bit more info using another method. I hooked my pi to the monitor and pulled EDID info.
root@raspberrypioldpi:~# tvservice -s
state 0x120006 [DVI DMT (57) RGB full 16:10], 1680x1050 @ 60.00Hz, progressive
root@raspberrypioldpi:~# tvservice -m DMT
Group DMT has 4 modes:
          mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
          mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
          mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
 (prefer) mode 57: 1680x1050 @ 60Hz 16:10, clock:119MHz progressive
root@raspberrypioldpi:~# tvservice -m CEA
Group CEA has 7 modes:
          mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
          mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
          mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
 (native) mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
          mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
          mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
          mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
Thats the simple stuff, attached is the output of;
root@raspberrypioldpi:~# tvservice -d edid.dat
Written 256 bytes to edid.dat
root@raspberrypioldpi:~# edidparser edid.dat > edid.txt
Also adding full pi serial console boot log.
root@raspberrypioldpi:~# cat /sys/devices/platform/soc/soc:fb/graphics/fb0/modes
U:1680x1050p-0
ATTENTION Moderator Note
Forum doesn't allow upload of files with the extension .log seriously? Might what to address that lol.
Have edited kernel startup params as some others have mentioned no luck
Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend,disp.screen0_output_mode=EDID:1280x720p60, earlycon=uart,mmio32,0x01c28000 mac_addr=7a:6e:63:ac:21:f1 root=/dev/mmcblk0p2 ro rootwait
.txt   edid.txt (Size: 3.7 KB / Downloads: 521)
.txt   putty20160420093457.txt (Size: 16.37 KB / Downloads: 554)
Ongoing HDMI limited compatability - by rahlquist - 04-19-2016, 07:21 AM
RE: Ongoing HDMI limited compatability - by Jasu - 04-24-2016, 04:50 AM
RE: Ongoing HDMI limited compatability - by rahlquist - 04-20-2016, 06:47 AM
RE: Ongoing HDMI limited compatability - by tllim - 04-20-2016, 08:08 AM
RE: Ongoing HDMI limited compatability - by tllim - 04-21-2016, 11:59 PM
RE: Ongoing HDMI limited compatability - by tllim - 04-21-2016, 03:35 PM
RE: Ongoing HDMI limited compatability - by tllim - 04-21-2016, 03:37 PM
RE: Ongoing HDMI limited compatability - by tllim - 04-22-2016, 12:02 AM
RE: Ongoing HDMI limited compatability - by tllim - 04-25-2016, 12:42 AM
RE: Ongoing HDMI limited compatability - by tllim - 12-27-2016, 11:45 PM
  lcd touch screen and hdmi output moreaujacky 2 7,463 10-24-2018, 07:24 AM
Last Post: lisanke
  No HDMI Display need help with correct uEnv.txt settings dkebler 7 15,239 01-11-2018, 02:52 PM
Last Post: dkebler
  HDMI Compatability rahlquist 5 11,745 07-29-2017, 02:32 AM
Last Post: qwerty2002
  No HDMI Output martinarcher 2 8,768 04-28-2017, 07:05 AM
Last Post: martinarcher
  Thoughts on eoma-68 compatability? traverseda 4 9,736 02-23-2017, 06:47 AM
Last Post: lkcl
  Switching from touchscreen to HDMI AUDIOTEK 10 18,891 08-11-2016, 07:41 PM
Last Post: MarkHaysHarris777
  4K HDMI video output medapeta 3 9,304 06-10-2016, 04:36 PM
Last Post: shinobi
  HDMI Issue... LeRoms77 4 10,554 04-19-2016, 02:11 AM
Last Post: LeRoms77
  nexdock (laptop style HDMI display w/ BT keyboard/touchpad) neoaeon 5 11,781 03-10-2016, 07:43 PM
Last Post: hrh1818
  Kickstarter Limited PINE64 T-Shirt - $999 shipping cost to Poland logrus 3 8,677 02-18-2016, 06:53 AM
Last Post: Ghost
