How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI
(12-13-2018, 09:48 AM)fosf0r Wrote: It sounds like your first cmake didn't actually succeed.
The first cmake is like "./configure" for traditional compilation.
It is checking for libraries, dependencies, and certain scripts and bin tools.
If it doesn't succeed, it won't create the Makefile for the second cmake step.
You will need to install whatever it is complaining about, then run the first cmake step again, and keep installing the things it's complaining about until it actually succeeds.
I simply did 'apt install' of 90% of the things it asked for and it was fine.
(Unfortunately, I didn't make a list of those things, would have made this a lot easier.)
The problem with multi-threaded building (-j parameter with a number, like -j10), is that the errors get nested so deep you can't read them because of the multiple jobs running.
When any cmake step fails, switch to not using the -j parameter just so you can more easily see what is wrong.
Thought so, most likely missing a dependency, could you point me to where to find dependencies to install before making the build. I understand making the list might take time so if you just point me where to find them ill just install everything and cross my fingers.
RE: How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI - by NightCrawler504 - 12-13-2018, 12:03 PM
  RockPro64 - HDMI and higher resolutions PakoSt 0 1,353 11-16-2021, 03:48 PM
Last Post: PakoSt
  OMV to Kodi Streaming Issues cogito808 12 16,936 05-25-2021, 08:30 AM
Last Post: helpmerock
  RockPro64 Linux Manjaro HDMI 4K mkne 12 14,532 05-03-2020, 07:23 AM
Last Post: PakoSt
  Debian, Kodi and the Spotify plugin. Pineapple 1 2,874 10-14-2019, 10:02 PM
Last Post: SBCraok
  Linux distro that will work with Kodi? SBCraok 9 11,774 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
  Does anyone have kodi working? blahblahblah 6 7,213 07-19-2019, 08:09 AM
Last Post: PackElend
  issue with kodi freezing randomly Slam 3 3,868 05-24-2019, 03:53 PM
Last Post: mknawabi
  HDMI audio solved yoramro 2 5,537 01-29-2019, 10:01 PM
Last Post: fczuardi
  kodi and /dev/rkdev catalinii 0 2,286 08-09-2018, 10:38 PM
Last Post: catalinii
