How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI
I have not yet tested Big Buck Bunny, was not aware of that as a thing, but now I am.
I will download it tonight and see if the rockpro64 can handle it!
rkmpv is an included script in the ayufan images that launches mpv for you with the proper switches on the end.
I edit that script and add my own enhancements/changes.
do this:
cat `whereis rkmpv`
That will show you what is passed to mpv.
I am remote and can't see mine right now to tell you, so if you cat that script you'll get it.
I also edited the LD library path line in there and removed the '/gbm' part from the end of the path because that wasn't right for my setup.
(My mali libs are not inside sub-directory "gbm" because I don't need multi-lib here)
The part that most people don't have activated is rkvdec, which is disabled in all of the ayufan kernels I've tried so far.
If you do not have rkvdec enabled, then your rkmpv will perform exactly as you described.
If you DO have rkvdec enabled, then your rkmpv should not lose any frames, even at 3840x2160@60.
Enable rkvdec by editing the DTB, then you can use rkmpv.
RE: How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI - by fosf0r - 12-04-2018, 11:36 AM
  RockPro64 - HDMI and higher resolutions PakoSt 0 1,364 11-16-2021, 03:48 PM
Last Post: PakoSt
  OMV to Kodi Streaming Issues cogito808 12 17,011 05-25-2021, 08:30 AM
Last Post: helpmerock
  RockPro64 Linux Manjaro HDMI 4K mkne 12 14,595 05-03-2020, 07:23 AM
Last Post: PakoSt
  Debian, Kodi and the Spotify plugin. Pineapple 1 2,881 10-14-2019, 10:02 PM
Last Post: SBCraok
  Linux distro that will work with Kodi? SBCraok 9 11,813 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
  Does anyone have kodi working? blahblahblah 6 7,246 07-19-2019, 08:09 AM
Last Post: PackElend
  issue with kodi freezing randomly Slam 3 3,891 05-24-2019, 03:53 PM
Last Post: mknawabi
  HDMI audio solved yoramro 2 5,562 01-29-2019, 10:01 PM
Last Post: fczuardi
  kodi and /dev/rkdev catalinii 0 2,300 08-09-2018, 10:38 PM
Last Post: catalinii
