ROCK64 bootlocks with 2 usb drives
(11-24-2018, 07:41 AM)Obelisk64 Wrote: Hi, I'm veeery happy with my ROCK64 overall and I managed to setup Nextcloud manually on it. It boots via the USB3 port. (Armbian-Stretch)
I ran into a error though, which is really ruining my day:
I wanted to set another USB Flashdrive as the cloud storage, connected on a USB2 port. It all works fine when I connect it after the ROCK64 booted.
BUT the ROCK64 woun't boot at all when a second USB drive is connected. It locks before a screen output, so I think this is not an Armbian problem.
I suspect the SPI bootloader gets confused when it can't boot from the USB2 drive and it will skip booting from the USB3 port?
What I figured out yet:
Bootdrive connected on USB3 port, Storage drive connected on a USB2 port --> bootlocks before screenoutput
Bootdrive connected to a USB2 port, Storage drive connected to the USB3 port --> it boots and works perfectly fine
Question:
Can I force the bootloader to only boot from USB3 and don't check the USB2 ports?
[Image: rock64withusbsata.jpg]
You need a bigger PSU, that one probably is not stable enough...
Jokes aside if you try several times it eventually boot? im using allmost the same setup but i use both drives thru a powered usb3 hub, its a workaround instead of a solution but maybe works for you too...
ROCK64 bootlocks with 2 usb drives - by Obelisk64 - 11-24-2018, 07:41 AM
RE: ROCK64 bootlocks with 2 usb drives - by Trash_Can_Man - 11-24-2018, 04:46 PM
RE: ROCK64 bootlocks with 2 usb drives - by z4v4l - 11-26-2018, 05:19 PM
RE: ROCK64 bootlocks with 2 usb drives - by z4v4l - 11-28-2018, 06:05 PM
  DeskPi case alternative for ROCK64 v1k699 2 11,058 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 2,717 05-13-2025, 07:32 AM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 1 2,362 03-24-2025, 06:41 PM
Last Post: arunkhan
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 10 42,200 03-24-2025, 06:35 PM
Last Post: arunkhan
  Are HW design files available for ROCK64? irenek 3 9,133 12-11-2023, 09:31 PM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 3,375 04-26-2023, 11:38 PM
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 18,327 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 4,454 11-07-2022, 05:45 PM
Last Post: olivercfc
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 6,292 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
  Where can I find the ROCK64 POE HAT Zoz 2 5,585 06-08-2022, 12:44 AM
Last Post: Zoz
