8812au wifi driver OS
I am trying to get the 8812au driver working for wifi. I have checked and there are some threads here that address this. However, if I try and build from source or from packages, I cannot get it to work for various reasons. The way I tried most recently was evilbunny's .deb from his/her fileserver. I am using ayufan's Debian Stretch image, then just pull the file from evilbunny's server and attempt an install using apt: sudo apt install ./<debName>
I end up with an error bad return aarch64, which I assume is something to do with building for aarch64 and not arm64 as we should, but I think evilbunny has this working for arm64... Am I using the wrong image? Which OS is evilbunny's .deb for 8812au confirmed to be working for? Here is the link to evilbunny's server: https://files.evilbunny.org/
Note that I also tried manually building from source from gordboy's repo, but after some modifications the build fails because of directory reference issues (i.e directory does not exist) even though the directory does exist...
Anyway, I think simplest is to install the driver from evilbunny's .deb, but cannot get it to work.
Any help would be very appreciated.
Best Regards,
pane
8812au wifi driver OS - by pane - 11-18-2018, 09:16 PM
RE: 8812au wifi driver OS - by evilbunny - 11-18-2018, 09:31 PM
RE: 8812au wifi driver OS - by pane - 11-18-2018, 10:06 PM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 12:35 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 01:16 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 01:41 AM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 01:52 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 02:32 AM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 02:39 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 02:46 AM
  on-board ethernet driver michaelanburaj 0 2,710 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 3,161 03-26-2019, 07:28 PM
Last Post: Poincare
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 5,952 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
Lightbulb Wifi problem Nether494 13 24,970 11-28-2018, 01:48 PM
Last Post: Nether494
  WiFi on Armbian problem scalextrix 14 25,189 09-08-2018, 01:13 AM
Last Post: scalextrix
  OMV wifi setup (driver issue) six9 0 3,209 07-25-2018, 03:34 PM
Last Post: six9
  wifi dongle pas059 3 5,722 05-30-2018, 12:25 PM
Last Post: pas059
  rtl8812au driver install.. 11b2p508 11 22,897 05-20-2018, 01:36 AM
Last Post: brajul
  How can I get a driver to support my USB wifi dongle Rocklobster 4 8,454 04-19-2018, 12:55 PM
Last Post: Rocklobster
  alpha wifi rt3572 cinaed 0 2,272 02-15-2018, 03:04 PM
Last Post: cinaed
