Tips and Tricks for Ayufan's Bionic LXDE Image
(11-17-2018, 09:32 AM)LeoLambda Wrote: Thanks to a lot of hard work from Ayufan and others, we have a working Bionic image that does sound, hardware video, suspend-to-RAM, and has good power efficiency. Unfortunately, it doesn't quite work out of the box, so here are the tweaks I've used to enable and enhance my experience on Ayufan's Bionic LXDE 0.7.28.
Getting WiFi
Installing network-manager-gnome and gnome-keyring (used for storing configurations securely) permits connecting to all kinds of WiFi networks including WPA2-Enterprise.
Make sure to use wlan0 and not p2p0 as the interface.
BUGS: No icon in system tray; you just have to click in the tray area until you get it.
HiDPI Scaling
The 1080p display on the 11.6 inch form factor is very high-DPI and thus scaling may be desired. To enable this on LXDE, create a .Xresources file in the home directory and add
Xft.dpi: 130
Replace 130 with whatever DPI setting is desired. 130 is a sane default, if a little small for some.
Enabling GPU Acceleration
Ayufan makes available packages for the the sunxi / Mali drivers (run pine64_enablea_sunxidrm.sh and install), but in order to use them, the libMali.so binary (in /usr/lib/aarch64-linux-gnu/mali/) needs to be symlinked at /usr/lib/aarch64-linux-gnu/libEGL.so.1 and at /usr/lib/aarch64-linux-gnu/libGLESv2.so.2 and those libraries need to be entirely moved away or removed somehow.
Getting a Better Panel
XFCE4 provides very useful software for use with LXDE. Installing xfce4-power-manager, xfce4-panel, and xfce4-goodies gives you access to a much nicer panel and menu (Whisker Menu).
Edit .config/lxsession/LXDE/autostart and replace the lxpanel line with a line for xfce4-panel, then log in and out and configure xfce4-panel to your liking.
PulseAudio Control
PulseAudio is installed by default, but you need pavucontrol to change settings in a sensible way.
To add keyboard shortcuts, you need xfce4-pulseaudio-plugin and lxhotkey-plugin-openbox. Install them and add the pulseaudio plugin to your panel.
I was wondering if you had a link to this image?
RE: Tips and Tricks for Ayufan's Bionic LXDE Image - by caps - 11-17-2018, 03:49 PM
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,763 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,161 05-07-2021, 10:20 AM
  Display battery charge value with LXDE and lxpanel wlad 1 4,812 12-04-2019, 03:36 AM
Last Post: pnts-se
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 5,946 08-14-2019, 04:27 AM
Last Post: matze79
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 1,926 06-11-2019, 01:36 PM
Last Post: k_mp
  KDE Neon Pinebook remix edition RC image bshah 67 119,000 05-18-2019, 11:44 AM
Last Post: rookieone
  Battery Status in Bionic X-Istence 3 4,964 03-11-2019, 03:52 PM
Last Post: soupbowl
  Pinebook X11 cursor gone after updating ayufan 0.7.30 fatalhalt 0 1,915 12-02-2018, 10:15 PM
Last Post: fatalhalt
Star New Pinebook releases (28.10.2018) - Ayufan Luke 5 6,742 11-08-2018, 03:54 AM
Last Post: Luke
  Armbian 18.04 (Bionic) for Pinebook Luke 0 3,238 08-17-2018, 02:28 PM
Last Post: Luke
