How to mount new microSD card?
(11-11-2018, 07:02 PM)acruhl Wrote: Wait, not mmcblk0! That's your running disk!
Use lsblk to figure out which one you want to format. If it's a microsd, it's probably mmcblk1 if you booted from the internal emmc disk.
Right, if you are running Legacy kernel.
But, for Mainline, Armbian Mainline for example, the eMMC will always be /dev/mmcblk2, either if you are booting from it or from SDCard ...
How to mount new microSD card? - by jschall - 11-10-2018, 12:03 PM
RE: How to mount new microSD card? - by evilbunny - 11-10-2018, 08:21 PM
RE: How to mount new microSD card? - by jschall - 11-11-2018, 06:37 AM
RE: How to mount new microSD card? - by acruhl - 11-11-2018, 07:45 AM
RE: How to mount new microSD card? - by jschall - 11-11-2018, 09:27 AM
RE: How to mount new microSD card? - by acruhl - 11-11-2018, 07:02 PM
RE: How to mount new microSD card? - by martinayotte - 11-12-2018, 10:30 AM
RE: How to mount new microSD card? - by jschall - 11-12-2018, 11:04 AM
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,608 12-07-2020, 04:02 PM
Last Post: SanjevR
Lightbulb Boot from SD card / boot options lodger 13 23,820 11-26-2019, 07:14 AM
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 1,954 05-19-2019, 04:46 PM
Last Post: Shoananas
  [SOLVED] Can't boot when SD card inserted jschall 5 7,642 11-17-2018, 11:53 AM
Last Post: jschall
  Boot from MicroSD ramboton 3 5,315 11-16-2018, 06:04 PM
Last Post: Luke
  Move Installation from SD Card to eMMC? soupbowl 4 8,683 11-10-2018, 10:47 AM
Last Post: acruhl
Question Installer shows SD Card size 0GB atr.mbl 1 2,901 08-16-2017, 11:13 PM
Last Post: MarkHaysHarris777
  SD CARD - EMMC jmbernabotto 3 5,554 07-14-2017, 12:54 AM
Last Post: pfeerick
