issues loading firmware and missing pci card
Sadly the list of successes in the RockPro64 PCIe slot is extremely short (excluding NVMe adapters and the Pine64 SATA card) - check the other threads around here.
Much of what you have in your log is "normal" with current kernel/DT, including the "invalid power supply". My log is below - I have a non-Pine64 NVMe adapter working just fine.
$ uname -a
Linux rpro64.dukla.net 4.4.138-1100-rockchip-ayufan-g95cecee47f40 #1 SMP Sat Sep 29 15:43:04 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
chris@rpro64:~$ dmesg | grep pcie
[    0.505910] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    0.505958] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.505998] vcc3v3_pcie: supplied by dc_12v
[    0.506064] vcc3v3_pcie: 3300 mV
[    0.506223] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    2.896829] vcc3v3_pcie: disabling
[    3.189423] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    3.189432] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    3.192960] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    3.192990] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    3.193080] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    3.193776] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    3.194052] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    3.194082] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    3.194149] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    3.212873] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    3.212919] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    3.212996] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    3.249922] rockchip-pcie f8000000.pcie: invalid power supply
[    3.322404] PCI host bridge /pcie@f8000000 ranges:
[    3.351488] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    3.430779] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    3.438222] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    3.452071] pcie_pme 0000:00:00.0:pcie01: service driver pcie_pme loaded
[    3.452389] aer 0000:00:00.0:pcie02: service driver aer loaded
{I stick to 4.4.138-1100 if I want sound, I use 4.19 to overclock.}
RE: issues loading firmware and missing pci card - by dukla2000 - 11-13-2018, 04:08 AM
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,043 02-17-2022, 12:10 PM
Last Post: flounder
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,424 10-29-2021, 11:15 AM
Last Post: TRS-80
  Overlays not loading at boot - ROCKPRO64 on Armbian rookieone 0 2,491 09-28-2021, 04:10 AM
Last Post: rookieone
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 2,562 07-24-2021, 09:46 PM
Last Post: Mentaluproar
  OMV to Kodi Streaming Issues cogito808 12 23,301 05-25-2021, 08:30 AM
Last Post: helpmerock
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 10,792 05-20-2021, 10:04 PM
Last Post: t4_4t
  Headphone jack issues Manjaro Mangled 2 4,325 03-06-2021, 11:01 PM
Last Post: Mangled
  Building a new SD card linuxha 2 4,866 04-27-2020, 12:32 AM
Last Post: linuxha
  rockpro64 and wayland - missing files Mentaluproar 1 3,778 08-14-2019, 07:51 PM
Last Post: hmuller
  Major issues with 0.8.3 bionic mate and PCIe TheSupercomputer 2 5,506 07-03-2019, 03:38 PM
Last Post: ayufan
