Open media vault on pine64?
(05-06-2016, 07:04 AM)Luke Wrote:
(05-06-2016, 06:19 AM)tkaiser Wrote:
(05-06-2016, 06:10 AM)Luke Wrote: I think that if I got it working it would be perfectly sufficient for my needs. As a side note, do you think that adding a an externally powered USB hub could remedy the power issue?
Such a powered hub is a prerequisite for external USB disks that don't come with an own PSU. Or the Pine64+ with 2GB DRAM and jumper setting DC-IN instead of BAT when also powered through the Euler pins. But in this mode you can't use a connected 3.7V battery to play UPS.
Given the DC-IN problems (undervoltage, max. current limited to approx. 1.8A by Micro USB), the current limitation of the USB port and both bandwidth and IOPS limitations of the USB port it simply makes absolutely no sense to use Pine64 as a NAS when way better boards are available. One exception: Being a Plex server since to my surprise Pine64 has enough horsepower to transcode a lot of movies that slower boards running with the 'NAS optimised' A20 would fail on.
Ok, great, that puts this to rest then Smile
Really for NAS use cases I/O bandwidth matters more. A nice A20 equipped Olimex Lime2 for example with a 3.7V battery and connected 2.5" SATA disk is a perfect example for a small, fast and reliable server (since here you don't run in undervoltage problems and the power limitations of the USB ports are higher so that even a spinned down disk when running on battery is not a problem when it suddenly wants to spin up again -- peak consumption 1A). And a few H3 boards do exist that feature 3 real USB host ports instead of just one like with Pine64. And ironically in Pine64 BSP we found an A20 successor called A20E that might be a little bit faster regarding CPU speed than A20 but has still SATA (and maybe an implementation that shows better SATA write speeds). Really: A64 is nice in other areas but not as a NAS.
BTW: I just had a look whether it's as easy to install OMV as it was with Plex, the usual
echo "deb http://packages.openmediavault.org/public kralizec main" >/etc/apt/sources.list.d/omv.list
dpkg --add-architecture armhf
approach. But this armhf OMV package is somewhat smelly (outdated) and requires PHP5. And while it's possible to install outdated PHP versions it's no good idea. So I dropped the idea since Pine64 is the wrong device for a NAS anyway...
Open media vault on pine64? - by Luke - 04-17-2016, 06:17 PM
RE: Open media vault on pine64? - by Suprazz - 05-05-2016, 05:56 PM
RE: Open media vault on pine64? - by frewind - 05-05-2016, 11:30 PM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 05:52 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 06:05 AM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 06:10 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 06:19 AM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 07:04 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 07:31 AM
RE: Open media vault on pine64? - by frewind - 05-06-2016, 12:58 PM
  Open Media Vault - Help needed janeku 3 8,123 04-01-2021, 06:36 AM
  Programming languages support under PINE64 baryluk 6 17,358 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 8,948 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 32,168 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 5,532 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 8,424 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 47,126 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,189 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,102 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 4,808 12-09-2017, 08:14 AM
Last Post: incoherent
