KDE Install on new Pinebook, howto?
(11-08-2018, 09:55 AM)Luke Wrote:
(11-08-2018, 09:21 AM)Corkonian Wrote:
(11-08-2018, 08:59 AM)Luke Wrote:
(11-08-2018, 06:40 AM)Corkonian Wrote: So what now? I have downloaded and etched the latest KDE image on a micro SD.
Now I put the card into the Pinebook and that thing boots into a nice Linux KDE Desktop.
Now, how do I move that image to the eMMC?
Bear in mind, the eMMC is empty and unformatted, I only have the KDE on the micro SD....
Everything you need is in the wiki - NOOB section. But I'll make it easy for you: option 1) download the image you want to your installation running from SD. DD the downloaded image  to the eMMC from within the environment on SD as you would on any other computer to any other media; option 2) use FEL SD card OR open up the Pinebook and use the FEL button + A-to-A cable.
Been there. Downloaded image and etched.
a) KDE Neon image doesn't show up as microSD to eMMC - which is akward.
b) No other cables or adapters available
c) sudo ./Pine64_install_to_eMMC.sh won't work as I only have an 8GB microSD at hand
I am not sure you understood me, read the Flashing to eMMC from a SD Boot (Allwinner A64 Devices) in NOOB section.
On the latest KDE image /usr/local/sbin is empty. No script there. No way to do a pine64_install_to_eMMC
RE: KDE Install on new Pinebook, howto? - by Luke - 11-08-2018, 08:59 AM
RE: KDE Install on new Pinebook, howto? - by Luke - 11-08-2018, 09:55 AM
RE: KDE Install on new Pinebook, howto? - by Corkonian - 11-08-2018, 11:06 AM
RE: KDE Install on new Pinebook, howto? - by Luke - 11-08-2018, 11:31 AM
RE: KDE Install on new Pinebook, howto? - by Luke - 11-08-2018, 02:11 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 3 12,540 11-28-2025, 07:38 AM
  DietPi OS for Pinebook MichaIng 3 14,127 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 93,289 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 4,640 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,524 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 13,198 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 7,264 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 9,195 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 9,972 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 7,491 01-20-2021, 11:18 AM
